ive gotten everything off the 91' 318is and now im waiting for my gaskets to come in. Is there anything thing else i should do while this stuff is off. Also any advice on how to make reassembly go smooth would be very helpful.
attempting to replace intake manifold gasket
Have you taken care of "the mess under the intake"? Google that phrase, and behold the horror.
'91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
'87 535i - Vacuum brake conversion [SOLD]'93 525iT - 5-speed swap - 320k and counting'09 328xi - 6-speed
that mess under the mani seems confusing but ill have to give it a shot theres a thread on m42club that should help. ill take that on the next rainy day i don't have to work. anything i should know before taking of the part of the manifold attached to the head, with the fuel rail or anyting ?Comment
The mess under the intake is easy enough, just make sure you have all the parts before tackling the job.
I didn't touch any fuel lines when I did mine.
I just did this on mine because one of the two small hoses was leaking. Just heat and rubber do not mix over long time. I always recommend changing those hoses everytime you remove the intake. The last thing you want to do is remove all that just for 3 inches of hose down the road. Its more pre-caution than anything. You can also have your injectors cleaned if they are original and never been done.Alex 88 m5 | 91 318is | 19 Subaru Ascent
BMW Tool Rentals & Fender RollerComment
