Idle Temps?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Idle Temps?
    What temp should the engine get around, mine is about 1/4th of the way on the temp guage, but I have never let it sit more than 10 minutes, and my heat isnt super warm. Maybe I will let her run for awhile tonight and see where it goes, if it doesnt warm up good, maybe a coolant flush is in order? And check the thermostat!
    • 34844
    between 1/4 and 1/2 is normal.
    • bmwm42
      • 6300
      yeah mine sits at 1/4 mark but my heater works hella good
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • DPIN
        • 67
        Mine sits just before 1/2 way mark. Heater works ok so so...
        1991 E30 318is Daily Driver
        2006 R171 SLK280
        2002 W203 C240
        • vegaskyle
          • Sep 2009
          • 121
          Mine would barely climb out of the blue but the heater worked like a charm. I put a new thermostat (88*c cheepo from pelican) in so I'll see if that changes anything. I'd bet it's the gauge that is off not the engine temp.
          If I were you I'd do a coolant flush. My car was full of that green shit and I'm sure it hadn't been changed in a while. Given that most breakdowns happen due to a cooling system failure a jug of BMW Blue and some time is well worth it. Make sure you drain the block, I couldn't believe how much more came out.
          • bmw325csi
            • May 2007
            • 4045
            mine sits at 1/4, if I idle for 5 minutes + it climbs another 1/8 but the heater is always hot.
            harry/harout
            • ///digitalme
              • Dec 2009
              • 2088
              mine sits shy of the middle
              • vegaskyle
                • Sep 2009
                • 121
                After the new thermostat its right between 1/4 and 1/2.
                • romeomike
                  • Apr 2009
                  • 71
                  With an 88C thermostat, it ranges from 3/8ths to just to the left of the halfway mark.
                  On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    Alright, just thought it was odd that I sat about 1/4 up, but I guess thats normal! thanks again!
