First of all I know this is a 3 year old thread, but my car has the same coolant leak symptoms, and I wonder if this fix sorted it out for you.
M42 maintenance list
bumping thread back...
how did you remove the crankcase bolt? any pics?Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Breaker bar to block of wood on driver side frame rail. Bump starter until it breaks loose. Be sure injectors or fuel pump are unhooked.
My impact couldn't break it loose so this was the only way I could do it. Ghetto, but effective.Comment
can you replace the profile gasket by removing the bottom case and leaving the top case intact?Renting my rear wheel bearing tool kit. SIR
If engine is on a stand? I'd rather not have to take the head off at this point.Renting my rear wheel bearing tool kit. SIR
