M42 maintenance list
  • Nairb
    • 1214
    #46
    Here is my almost-complete list of things that I have replaced or added to my 1991 318is.. I did not add seals or gaskets to the list for the most part, because I just think that it's common knowledge to replace such things when doing work on a car. (For example, valve cover gasket when I had it powdercoated, etc)
    With that said, depending on the maintenance history of your car.. these would be a good place to check up on to see if they need to be replaced.
    Mods:
    Mark D 93 Octane Chip
    BBS RS 039/040 Staggered Wheels
    M-Tech Illuminated Shifter
    M-Tech 1 Steering Wheel
    Front/Rear Strut Bars
    Pioneer TS-D502P 5x1.25 Rear Speakers
    Pioneer TS-A532P 5x1.25 Front Speakers
    Pioneer TST15 3/4" Tweeters
    Pioneer Premier DEH-P310UB Head Unit
    Bilstein Sport Shocks (July 2010)
    H&R Sport Springs (July 2010)
    Diverse Motorsport 15mm Drop Hats (July 2010)
    20% Charcool Lifetime Warranty Tint
    K&N Air Filter
    Euro License Plate
    OEM BMW Mud Flaps
    GG Interior Light Delay
    Powdercoated Intake Manifold/Valve Cover
    Deleted Power Steering (powersteeringdeletes.com)
    Maintenance:
    New Behr Radiator (April 2011) (145,000)
    New Upper and Lower Radiator Hoses (April 2011) (145,000)
    New Thermostat (April 2011) (145,000)
    New Meyle Front Wheel Hubs (April 2011) (145,000)
    New Powerflex Rear Subframe (February 2011) (144,000)
    New Powerflex Rear Trailing Arm Bushing (February 2011) (144,000)
    New Powerflex "Race" Differential Bushing (February 2011) (144,000)
    New CV Boots (February 2011) (144,000)
    New Bosch O2 Sensor (February 2011) (144,000)
    New Pinion Seal (February 2011) (144,000)
    New OEM Front/Rear Brake Lines (February 2011) (144,000)
    New Rear Swaybar Links (February 2011) (144,000)
    New OEM Steering Rack (September 2010) (142,500)
    New Front/Rear Shock Mounts
    New Odometer Gears (December 2010)
    New OEM Hella Interior Light (August 2010)
    New Fuel Filter (July 2010)
    New Control Arms (July 2010)
    New Tie-Rod Assembly (July 2010)
    New Polyurethane Control Arm Bushings (July 2010)
    New Front Sway Bar Links (July 2010)
    New Timing Chain Tensioner (March 2010)
    New Oil Filler Cap (March 2010)
    New 4-Pintle Bosch Fuel Injectors [Part #:0 280 155 710] (September 2010)
    New OEM Bosch Spark Plugs (September 2010)
    New HQ Autosport Coil On Plug Kit (September 2010)
    New Zimmermann Front/Rear Cross-Drilled/Slotted Rotors (July 2010)
    Fixed the "Mess Under The Intake" (September 2010)
    Royal Purple Differential Fluid (July 2010)
    Crack Free Dash (December 2010)
    My 1991 318is Progression Thread
    • Simon S
      • Oct 2004
      • 3758
      #47
      This post is in regard to my discoveries when addressing profile gasket surface on my m42 timing case. It involved the 'internal' coolant leak mentioned earlier. Honestly - it's a little weird - after seeing and addressing the issue - I really couldn’t see where this failure would/could cause long-term after effects. In other words, it's a coolant leak to a closed-off area in timing case that really doesn't seem harmful. Nevertheless, here are pictures of my discoveries.
      Tore it down to the short block. Wanted to replace all gaskets.
      What front of block looked like (note corrosion from "interior" coolant leak):
      Back of timing case / how water pump was removed:
      The timing case itself was a neat part. As I cleaned it - I was impressed with the amount of design and machine work it would take to manufacture.
      Top of case
      (failed) Relationship of case and profile gasket
      Close up of poor casting
      Tools used
      Gooped up with JB weld
      Shot of cylinder head at same connection point (ug! what's the deal here?)
      (JB weld repair setting as I type this)
      JB weld repair completed on timing case. New profile gasket test-fits perfectly in groove.
      Hopefully - that should be the end of that..
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • Matt-B
        The Waffler
        • 3856
        #48
        Nice Job Simon
        • Simon S
          • Oct 2004
          • 3758
          #49
          So nice when you finally figure something out.
          As long as I’ve had my car – (storing and working on it mostly) I’d note drops of green-ish/blue-ish liquid on bottom of A/C compressor. I couldn’t tell if it was the compressor leaking some funky lubricant or what.
          Before I put my head back on – I noted an ‘open’/no gasket area between block and front timing case.
          So the bad casting issue I had with the case would cause coolant to slowly leak out from that open area – which is right fucking above the A/C compressor.
          • Simon S
            • Oct 2004
            • 3758
            #50
            The more I think about it - the more I'm sure it was the 'green coolant' that the PO used in my car - that caused the pitting.
            Not 'poor casting'.
            Jesus - even my thermostat housing was eaten up..
            STAY AWAY FROM GREEN/PARTS STORE COOLANT !!
            It will eat your aluminum components up.
            edit: plus probable electrolysis as discussed below
            Last edited by Simon S; 05-26-2011, 09:04 PM. Reason: correction per additional information
            • JoeyBones
              • 422
              #51
              hmmm...uh oh...mine is loaded up with prestone premix... it said it was safe for all types...and the old was green too...
              • Dj Buttchug
                • Jun 2010
                • 7688
                #52
                some of the pitting is also caused from electrolysis. It is more common on engines with aluminum heads. Custom made ground wires can really help with this issue.
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • Simon S
                  • Oct 2004
                  • 3758
                  #53
                  Interesting.
                  Well shit - I guess my engine is getting a second ground strap put on it..
                  • Ryann
                    • 3350
                    #54
                    True story. I've seen a 16v Honda head eaten alive by this very issue.
                    • Simon S
                      • Oct 2004
                      • 3758
                      #55
                      Cool. Thanks guys. I'm really pleased with how informative this thread has become.
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        #56
                        Originally posted by Simon S
                        Interesting.
                        ya man, do like a 6 or 8 gauge wire. I grounded once to the block and once to the chassis.
                        Ig:ryno_pzk
                        • b15azn
                          • Dec 2009
                          • 88
                          #57
                          WOW good thread and i was wondering the list this morning, glad ppl put it out here.
                          But I have a quick quesiton, my M42 still pulls strong and it has 200,000 miles on it. It seems the previous owner has done some maintenance ......still any thought?
                          • KenC
                            King of Kegstands
                            • 14396
                            #58
                            It doesn't matter what color the coolant is, just make sure it's safe for aluminum heads.
                            The green coolant from the 80s and 90s wasn't.
                            Simon, I'm VERY surprised your engine lasted that long without the updated profile gasket.
                            Originally posted by Gruelius
                            • KenC
                              King of Kegstands
                              • 14396
                              #59
                              There's no way to speculate unless you take the timing covers off and start inspecting.
                              • JoeyBones
                                • 422
                                #60
                                seems like i'm always adding something more to the list of things i need to do to get the car to a good "baseline" before I start any really fun mods.... excluding putting in the racing seat which i justify as a necessity due to the previous seats being sold to fund other maintenance ...
                                I just need money...
