M42 maintenance list
  • 5ickride
    • 2922
    Just recently picked up a 318ic and want to do an overhaul on engine maintenance. Can someone let me know what items i should start replacing...timing chain?...
    Thanks
  • bmwm42
    • 6300
    timing chain tensioner would be first on the list
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • Dj Buttchug
      • Jun 2010
      • 7688
      all fluids changed.
      lower pan gasket. locktite bolts
      delete useless hoses ect
      timing chain guides and tensioner
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • shEck3lls0
        • Jan 2011
        • 1154
        What do you mean useless hoses?
        1989 Alpine 325is 2dr m50 swapped
        Build Thread:
        Current ongoing build. Check it out!
        1991 318is 4dr rallycross
        Rallycross Build Thread.
        1991 Alpine 318is coupe - sold
        • Dj Buttchug
          • Jun 2010
          • 7688
          mess under the intake. delete the heater plates in the throttle body as well.
          theres a huge mess of coolant lines you dont need under the intake mani
          Ig:ryno_pzk
          • Eecen
            • Jun 2010
            • 1235
            Check out m42club, site devoted to that rattly little bastard.
            disclaimer; I enjoy my m42, even if it is slow.
            • KenC
              King of Kegstands
              • 14396
              Check the condition of the chain guides, and the cam gears. Update the uppermost chain guide to the all plastic version. Profile gasket if it hasn't been replaced. Also, there is an updated oil pressure relief valve.
              Originally posted by Gruelius
              • NightfoxCT
                • 23
                Recommend checking out a few of your sensors also. Tps/ 02/ coolant
                Clean out Trottle body and ICV
                Valve adj.
                and everything above
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  valves are hydraulic. no adjustment is needed
                  Ig:ryno_pzk
                  • MikeDE
                    • 1873
                    I lol'd, woke up my kids.
                    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                    • 5ickride
                      • 2922
                      Thanks, I also just bought a MarkD chip to go along with the maintenance, hopefully she'll be a gem when she's done.
                      • Massimo
                        • Jan 2008
                        • 3207
                        Pull engine
                        Rebuild 2.1lt.
                        LOL
                        Seriously though it depends how far you want to go. A list of things I would recommend listed as high priority to low priority.
                        Change Fluids
                        Timing Chain Tensioner
                        Check oil pick up bolts
                        Mess under the intake
                        Delete Heater Plate.
                        Water Pump
                        Thermostat
                        Timing Components
                        Fan Clutch
                        COP Kit
                        Mustang Injectors
                        VW lifters
                        And if you are really keen and competent get a Head Gasket kit.
                        • Simon S
                          • Oct 2004
                          • 3758
                          ^^ good list right there
                          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                          • Ryann
                            • 3350
                            It may or may not need anything. How many miles on the ODO? Did it come with any service records? I say if it's without chain rattle, idles nice, and doesn't loose coolant just change the engine/trans/diff oil, fuel filter, and air filter and drive it.
                            • 5ickride
                              • 2922
                              Originally posted by Massimo
                              Pull engine
                              Rebuild 2.1lt.
                              LOL
                              Change Fluids
                              Water Pump
                              Thermostat
                              Timing Components
                              Fan Clutch
                              COP Kit
                              Mustang Injectors
                              VW lifters
                              Thanks for that list! QQ, what are the "Mustang Injectors" for? Performance? Also, my ignition coils seem to be good ATM, but should I still see about getting a COP kit?. Finally, what are "VW Lifters?"
                              She's got under 106k and no records besides what I was told. The Idle is bouncy when I start her up but then settles and idles fine once engine is warm.
                              I've put together a list of what I'm thinking about changing:
                              -Belts (AC, PS, Alt)
                              -Intake Manifold Gaskets
                              -Water Pump/T-Stat
                              -Valve Cover Gasket
                              -Timing Chain Tensioner
                              -Timing Chain Guides (plastic version)
                              -Lower Pan Gasket
                              -Profile Gasket
                              -Oil Pressure Relieve Valve
                              -Sensors (Crank Position, o2, Coolant, Camshaft Position)
                              -Hoses (water, coolant)
                              -Filters (oil, fuel, air)
                              -Spark Plugs
                              -Fan Clutch
                              -Fluids (oil, trans, diff)
                              I'll also:
                              -Delete Heater Plates
                              -Delete the useless coolant lines under the IM
                              -Clean out throttle body and ICV
                              Anything major that i'm missing?
                              Thanks
