Oil Pump Pickup
  • AndrewBird
    The Mad Scientist
    • 11898
    Oil Pump Pickup
    I'm starting on building a new oil pan for my MGB project and have a question. The stock pan has the pickup built into the upper pan and has a slot/gallery to cover two holes in the block as seen here:
    Here is basically where the "slot" covers on the block.
    The round hole looks to go to the oil pump while the more square shaped one looks like it is a drain from the timing cover.
    My question is, do I need to encase both of these like the stock pan does, or can I make the pickup only over the round oil pump hole?
  • Simon S
    • Oct 2004
    • 3758
    Damn – I wanna help – but don’t want to give you bad info..
    For things like this – I usually think in terms of “keeping it like the factory designed it”.
    i.e. encase both.
    I know the round thing behind retainer clip is the oil pressure relief valve – and if it’s in an open housing along with the square-ish hole – it leads me to believe that its design/operation is dependant on that set up.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • AndrewBird
      The Mad Scientist
      • 11898
      At first I was thinking it would be difficult to encase both, but I've been working on the pan design tonight and it looks like it shouldn't be a problem. I'm with you on the "keep it factory" part. I'd rather not loose oil pressure due to something stupid like this.
      • Simon S
        • Oct 2004
        • 3758
        Exactly.
        Really looking forward to seeing how you overcome some of the challenges you'll face.
        Thanks again for those stickers from a while back - btw..
        <3 them.
        • Dj Buttchug
          • Jun 2010
          • 7686
          okay. the round hole with the e clip is the pressure relief valve. the square hole is the actual pickup
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
