Interesting coolant issue
  • Car Addict
    • Mar 2007
    • 1100
    new issues look down a few posts.vvvvvvvv
    Alright so what would cause both hoses from the radiator to the thermostat housing to be ice cold after running for 8 minutes and the temp gauge is just a little above normal operating temp?
    Quick background
    Vehicle been stored since November
    Just finished replacing thermostat, water pump and all associated gaskets.
    New fan clutch
    New hoses
    New BMW coolant
    Bunch of other engine work but that is all tha was replaced that dealt with the cooling
  • KenC
    King of Kegstands
    • 14396
    Enough coolant in the system?
    Originally posted by Gruelius
    • Dj Buttchug
      • Jun 2010
      • 7665
      or big air pocket... fill and re-bleed??
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Car Addict
        • Mar 2007
        • 1100
        I would rebleed but the issue is before the coolant level begins to drop the temp gauge hits the next line after normal operating temp and I decide to kill it.
        • KenC
          King of Kegstands
          • 14396
          Sounds like your water pump isn't working or you are really low on coolant.
          • Matt-B
            The Waffler
            • 3856
            Let motor get cold, fill to COLD line on resovoir, start car, turn on heater etc, bleed car, then recheck, if that does not help...
            maybe somehow you put your thermostat backwards?
            • Car Addict
              • Mar 2007
              • 1100
              Alright so now the upper radiator hose is nice and toasty and so is the left side of the radiator. However the right side of the radiator is cold and so is the lower radiator hose. Before I started bleeding the system again I rechecked the thermostat was working and installed correctly both are alright.
              The temp. gauge stays right in the middle now, but I still have no heat. I have been bleeding the car for the past few hours, aka 10 minutes here then an hour later another 10 minutes. I am bleeding it with the front of the car on jack stands to help with the removal of air.
              Any clues?
              • Ryann
                • 3350
                Mine's been doing this INTERMITTANTLY!
                The sheer number of cooling system anomalies experienced with our cars continues to blow my mind. There should be a bleed screw on top of the fuckin' TB heater plate. Shit.
                • Car Addict
                  • Mar 2007
                  • 1100
                  ^ true facts
                  • bmwm42
                    • 6300
                    hmmm mine is doing the same shit. on mine temp gauge stays in the middle always the top hose is hot as shit and the lower is well cold mostly. i always have nice hot heat. it has brand new cooling sys, timing componets etc. yet the lower rad hose is cold most of the time?
                    Originally posted by bmwm42
                    PNW vulture pm me for parts
                    Strategic nw e30 command
                    • ///digitalme
                      • Dec 2009
                      • 2088
                      mine did the same...i dont know what fixed it but i flushed the system, replaced the thermostat, and replaced the temp sensor on the radiator, then the bleed screw on the radiator and it fixed everything.
                      • Matt-B
                        The Waffler
                        • 3856
                        clogged rad?
