Transmission and Diff Fluid
  • keada714
    • Apr 2011
    • 424
    hey,
    I was doing a little search and I couldn't get a straight answer on what fluid to use on my transmission. I been hearing to use ATF, 75w90 gear oil, and redline mt 90. I also heard for the diff use 75w90 gear oil. I'm a little confused of what to buy. So any help is greatly appreciated. Thanks!
    Mark
  • Dj Buttchug
    • Jun 2010
    • 7688
    your trans will take well to a decent atf. I use a redline product. For your diff, it depends. Some run 75-90 others use thicker. dont forget if your LSD make sure to use a friction mod when changing fluids in the diff.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • ///digitalme
      • Dec 2009
      • 2088
      i use redline gear oil on the lsd
      and redline mtl on the tranny
      the mtl helped a lot, shifts are smoother
      • keada714
        • Apr 2011
        • 424
        Everyone has different opinion I guess. I see that a lot of people are recommending MTL and other are sticking with the ATF
        • KenC
          King of Kegstands
          • 14396
          Mobil 1 full syn ATF.
          Originally posted by Gruelius
          • keada714
            • Apr 2011
            • 424
            can anyone give pros and cons of Mtl or Atf
            • KenC
              King of Kegstands
              • 14396
              ATF has detergents and is pretty thin. Less loss due to fluid viscosity.
              MTL is a little thicker. I think that contributes to the "smooth" shift feeling.
              Either is fine. Just get what's available next time you're at the store.
              • ///M42 sport
                • 3952
                redline?
                • Ryann
                  • 3350
                  You live in a warm climate, go with Redline MTL. You'll like it better.
                  • jrobie79
                    • Mar 2006
                    • 2526
                    I use Redline MTL in the tranny and Motul Gear Competition 75-140 in the LSD
                    1991 318i ---- 308K - retired
                    • Nick_S
                      • Apr 2011
                      • 3658
                      Just changed my dif oil about a month ago. No idea when it was done last so figured why not. I used Mobile1 75w-90LS for the LSD. Can't honestly tell a bit of difference from whatever was in it. Trans is up next.
                      91 318is M50 swapped
                      05 Honda Pilot
                      24V swap thread
