M10 Turbo Manifold on M42?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Can it happen?
  • Holland
    • Nov 2008
    • 7212
    IIRC the inlet spacing differs between the two engines. Adapter perhaps?
    Originally posted by DEV0 E30
    • GunMetalGrey
      • Dec 2010
      • 1499
      Idk, but you can get m10 turbo manifolds on the cheap. M42 not so much
      • AndrewBird
        The Mad Scientist
        • 11898
        M5x motors use the same spacing. I know Danny modified an M5x turbo manifold for his turbo M42. Just cut off two pipes and weld the opening shut.
        • bmwm42
          • 6300
          M10 manifold will not fit m42
          Originally posted by bmwm42
          PNW vulture pm me for parts
          Strategic nw e30 command
          • Dj Buttchug
            • Jun 2010
            • 7686
            wont fit. buy m50 manifold flip and chop off the last two cylinders, as said before its about 150 bucks or so by the time your done
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • GunMetalGrey
              • Dec 2010
              • 1499
              Best place for m50 manifold? ebay only has 198 $ ones
              • Dj Buttchug
                • Jun 2010
                • 7686
                that seems like more than i paid for mine. this is style you need. The cast ones wont work because you need to be able to hack it up and mod it.
                http://cgi.ebay.com/BMW-M50-M52-Turb...item2c58e4bbff
                this is UK which sucks... maybe the price has gone up :(
                Ig:ryno_pzk
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  Any advice for pulling the old manifold off? Those bolts dont look like fun
                  • Dj Buttchug
                    • Jun 2010
                    • 7686
                    pb blaster some beers and a afternoon. its alot easier from underneath, even more so with the engine out obviously. The pb blaster should get em tho.
                    Ig:ryno_pzk
                    • PFCRayB
                      • Nov 2009
                      • 403
                      and a bfw a really bfw, buy yea the m5x manis work good, o and also dont skim on the head gasket
                      Originally posted by Erick
                      Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        Planning on running low boost for a bit so I dont need to change the Head gasket. And if by bfw you mean big fucking wrench, I have that :)
                        • PFCRayB
                          • Nov 2009
                          • 403
                          I was only running 8 and blew mine.......and yep a big fucking wrench
                          • GunMetalGrey
                            • Dec 2010
                            • 1499
                            ahh, I really don't want to change the Head gasket.....
                            • PFCRayB
                              • Nov 2009
                              • 403
                              Just do it and then when you want more power you don't need to worry about it later
