M10 Turbo Manifold on M42?
  • GunMetalGrey
    • Dec 2010
    • 1499
    True, DJ what one did you use? it looked sick!
    • Dj Buttchug
      • Jun 2010
      • 7688
      its all in the tune... stock head gasket and stock internals will pop at 12psi if its tuned right... fwiw im on a stock head gasket...
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • GunMetalGrey
        • Dec 2010
        • 1499
        Stock fuel management=?
        • PFCRayB
          • Nov 2009
          • 403
          Its true about the tune, I was boosting at 15 then I started getting predet so changed wastegate springs. O btw I blew a mls one and am using a rising rate fpu
          Originally posted by Erick
          Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
          • Dj Buttchug
            • Jun 2010
            • 7688
            far from... heres what im running
            forged cp pistons 8.5:1
            1000 cc injectors
            full arp hardware, head studs, main studs and connecting rod bolts
            255 TRE fuel pump stock lines fuel rail and FPR
            there is more as well.
            check out my build if you havent already. Ive slowly become an expert with this engine after all ive gone through with it.
            Ig:ryno_pzk
            • GunMetalGrey
              • Dec 2010
              • 1499
              saw that, you never put what head gasket you used.
              • Dj Buttchug
                • Jun 2010
                • 7688
                it was a victorreinz OEM type but after it crapped out on me i switched to a goeteze or whatever.
                Ig:ryno_pzk
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  http://store.vacmotorsports.com/vac-...rce=googlebase
                  Worth it?
                  • aka-e30
                    • Jul 2011
                    • 15
                    What do you guys think about this mani? its for a e36 m42/44. would it be worth it or would it even work? They have one without the DP thats a little cheaper. Its not near as cheap as an m50 mani chopped tho. http://www.ebay.com/itm/OBX-TURBO-HE...e800c4&vxp=mtr
                    • aka-e30
                      • Jul 2011
                      • 15
                      It seems like all the m50 manis and the one above is t3/t4 flange based. i was planning on using a used t25 from an sr20. would that work with these manis?
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        the e36 m44 mani will bolt up but it wont fit in the e30 chassis. You have to run m50x manifold modded. you also have to chop off the t3 flange and do up a t25 flange
                        Ig:ryno_pzk
