M42 Crank bolt removal
  • Simon S
    • Oct 2004
    • 3758
    that can depend on the equipment though too..
    e.g. I've got a cheapy 3/4" impact and a waffleswaffleswaffleswaffleswaffles HF compressor - and dude, that ain't shit to what I can get off with my breaker bar and dead blow..
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Brink
      • Jul 2011
      • 12
      I'm going to go try a few things and report back after, wish me luck
      • Ryann
        • 3350
        True dat.
        • glucklich21
          • 1912
          I bought a new 1/2" impact just for this. At 90 psi 340 ft-lb at my fingertips. :)
          • KenC
            King of Kegstands
            • 14396
            Take the lower pan off and wedge a 2x4 between the inside of the block and the crank counterweights.
            Originally posted by Gruelius
            • e304me
              • Feb 2006
              • 1374
              yeah ive done this
              • Brink
                • Jul 2011
                • 12
                I took the clutch and flywheel off and out two flywheel bolts back in and wedged a hammer in between them and the ground. I put a breaker bar on it and me and my little brother stood in the end of it and it finally broke loose. Then I took the oil pan off and found metal shavings and that 3 of my 4 rod bearings are jacked. The end! :(
                • Simon S
                  • Oct 2004
                  • 3758
                  < insert sad frog meme >
                  • rjcaptsean
                    • Jul 2009
                    • 51
                    This, but opposite:
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      op, when you do get the bolt off fwiw it doesnt need to be that tight when you re-install it.
                      a little lock tite on the threads/ bout 60ft lbs torque and your good. at least thats what i did. makes it a hell of alot easier if you do have to remove it again later
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • Ryann
                        • 3350
                        Shitty!
