part# anyone?
  • b15azn
    • Dec 2009
    • 88
    part# anyone?
    Picked up this 318is not a long time ago, the car is doing very well. 200k miles on clock. Today, I tried to do some maintenance before I decide to do some stupid stuff
    So when I took off my valve cover, the timing chain looked okay to me. My mechanic told me that piece of plastic next to the chian probably need to replace because it seems kind loose and some wore out.Also he suggested me to replace the chain as well(get the timing chain kit)? suggestion? Also, anyone know what's that piece called? and part #?
    Can someone tell me who should I purchase OEM parts from of this site for good price?
  • Cong405
    • Jul 2009
    • 590
    Use Realoem.com to look up part number.
    http://realoem.com/bmw/showparts.do?...67&hg=11&fg=25
    That plastic piece should be #20 on the list.
    Since your cover is off, you should change the gasket too if that haven't been changed
    As for places to buy parts... I usually shop at pelican parts or getbmwparts.com (i find them to be a little cheaper than pelican). I know there's a thread on the forum that list all the stores that people shop at if you search for it. I've read somewhere that you should PM blunts for parts too so I suggest you give him a shot.
    • tonywonder
      • Sep 2009
      • 1688
      take pics of cam gears. what plastic piece is he referring to?
      • b15azn
        • Dec 2009
        • 88
        thx you so much, i will keep using search engine on here before i got flamed lol Any key words to put in so i can find the store? yeah i do know Blunt :d just see if there's other options in the market :d forgot to add on my post, I will also redo my headgaskets and o-rings.
        • b15azn
          • Dec 2009
          • 88
          Don't you see my pics? the black plastic piece I referred to is the one sits next to timing chain. If you look at the last pics, you should see it.
          • tonywonder
            • Sep 2009
            • 1688
            i was just verifying what plastic piece u were talking about. theres more than one plastic chain guide. that top piece can be replaced but i would make sure its torqued to spec first. again take pics of the cam gears so we can see the teeth. going in there and changing the chain is a lot of work to do. do you know if and when the timing components were last serviced?
            • b15azn
              • Dec 2009
              • 88
              I just checked the RealOEM.com,the one you sent to me. Do you know where I can pull out/download for a pdf.file like this? I know for us Nissan guys, most of us have a FSM as a reference. I just ordered that piece(#20) and some gaskets and two oil filters for future maintenance. I have no clue when was the last time the po(previous owner)changed. Okay I will snap some pics of my cam gears tomorrow morning, and hopefully won't be that bad.
              • Cong405
                • Jul 2009
                • 590
                Your next oil change, you should take apart your lower pan to see if there are any loose bolts in there and change that gasket too.
                • b15azn
                  • Dec 2009
                  • 88
                  thx for the input, do i need to seal the pan as well?
                  btw do you know the part #?
                  • rjcaptsean
                    • Jul 2009
                    • 51
                    Might be too late, but make sure the Spark Plug gaskets are either included with your valve cover gasket, or you purchase them separately.
                    Numbers 4 (3 of them) and 5 (1)
                    http://realoem.com/bmw/showparts.do?...64&hg=11&fg=15
                    • Dj Buttchug
                      • Jun 2010
                      • 7673
                      not that anyone really cares but you dont need that gay timing guide piece.
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • rlddlr53
                        • Oct 2009
                        • 1450
                        re-install the valve-cover. sell the car. Buy a new 2011 M3
