Best M42 Mods
  • bannre10
    • Aug 2011
    • 18
    Best M42 Mods
    Hey Guys,
    I should be getting a 318is in good mechanical condition soon and was wondering what the best modifications to perform on one were? Preferably cheap modifications tho because I don't have too much money.
  • Teaguer
    • Sep 2004
    • 6167
    Originally posted by bannre10
    Hey Guys,
    First off make sure everything is up to par.
    Intake vacuum leaks are notorious on M42's due to the rats nest of lines under the intake.
    Then the mods can start. A good chip is always a great improvement on the M42.
    Here in the US MarkD seems to be the preferred choice.
    • MikeDE
      • 1873
      ^MarkD chip, Coil-on-plug kit, lighter FW. Not crazy light, makes it a bit trickier to drive. I have a 19lb non-ac FW & clutch on my M42.
      -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
      • immajackuup
        • Dec 2010
        • 1132
        mustang injectors 4pintle.
        • gearheadE30
          • Jun 2007
          • 3734
          If you go mustang injectors, make sure they are at least 19 lb/hr but less than 23 lb/hr. that seems to be the sweet range. Free-flowing cat back also helps, supersprint really being the best. You'll read a lot about M20 flywheels, but larger diameter and larger clutch pack means about the same overall mass. I have one machined down to 15 lbs and it's nice, but the only reason I went with an M20 one is to keep up with the turbo.
          Project M42 Turbo
          • mr ilia
            • May 2011
            • 582
            The best cheap mods:
            1) CAI - 100.00
            2) DME chip, MarkD or similar (Ebay) - 30.00 (Ebay) - 200.00 (markD)
            3) Advance intake cam - Free
            4) Freeflowing catback - From 100.00
            Good, but not so cheap:
            1) M20 clutch and flywheel setup
            2) COP
            3) 4.45 diff (?)
            • trackjunkie21
              • Jan 2010
              • 3962
              1) CAI - 100.00
              2) COP
              3) 4.45 diff (?)
              CAI does nothing and advancing the intake cam only moved the powerband up higher, really stupid to do if you use it as a street car.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • immajackuup
                • Dec 2010
                • 1132
                • mr ilia
                  • May 2011
                  • 582
                  CAI will only help if you use it in a combination of mods.
                  Agree as CAI only is help less.
                  Correct - Cam advance does not "add" any power, but it does help to generate power faster while in the top end.
                  Another good part of advancing the cam is the "feel" of power comming alive around 4.5k RPM, you feel this nice kick in the butt...once the motor goes past the 4500 rpm you can feel the small surge of power and faster acceleration with out extra throttle push. Very sweet spot...I love this feeling during acceleration.
                  • b*saint
                    • 3794
                    What is the difference between a ac and non ac flywheel?
                    Ma che cazzo state dicendo? :|
                    • KenC
                      King of Kegstands
                      • 14396
                      Non-AC ones are singlemass and a lot lighter. Never available in the US.
                      Originally posted by Gruelius
                      • Balleristic31
                        • Aug 2009
                        • 4198
                        Any write ups on advancing cam timing?
                        -NICK
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          super easy to do. pull valve cover. loosen cam gears on desired cam to advance. rotate clockwise till you reach your desired advance. clockwise when standing directly in front of your car.
                          Turbo M42 Build Thread :Here
                          Ig:ryno_pzk
                          I like the tuna here.
                          Originally posted by lambo
                          • Eecen
                            • Jun 2010
                            • 1235
                            Really?
                            My 318i didn't have AC...interesting.
                            • bannre10
                              • Aug 2011
                              • 18
                              So what is better a markd chip or a turner motorsports one I saw on pelican parts. Also I live in Australia. would markd do international shipping?
