91 m42 misfire out of ideas
  • B-well
    • 1042
    car is a 91 318. 90k original miles
    car has been problem free for 2k miles. then all of a sudden misfire thoughout rpm range.
    replaced fuel pump (mine was whining so it was needed anyway)
    replaced plugs. double platinum
    replaced wires. bosch 7mm premium
    replaced coils.
    replaced ecu
    the second cylinder coil is sparking at the coil and with plug in the end of wire it sparks, but when in the cylinder it does nothing. unplugging 1,3, or 4 causes it to nearly die but unplugging 2 has no effect.
    unplugged maf but still idles rough
    can the CAS effect only one cylinder? im out of ideas. any help is greatly appreciated.
  • Ryann
    • 3350
    If you're able to pull a sparking #2 wire without any effect then you're left with compression in #2 and fuel injection for #2. You can use a Bosch noid light ($10-15) to verify that #2 injector is getting a signal from your DME.
    • xxlbimmer
      • Dec 2010
      • 156
      Put a timing light on number 2 spark plug wire and look at the flashes and compare with others! Then, try swapping injector #2 with #3, see if it moves the problem. Hopefully a comp check was among your first items, if not do that!!
      Chris Leone
      chrisleonemotorsports.com
      rollcages and fabrication
      Remember cross threading is the only thing stronger than loctite!!
      • AndrewBird
        The Mad Scientist
        • 11898
        Pull your ECU and take a look at the transitors that fire the coils. They like to get hot and burn out.
        Thankfully they are easy to replace if you know how to solder. New ones are like $2 each.
        If any are burned up, you will want to make sure the coils are good as a bad coil will burn them out as well.
        • B-well
          • 1042
          swapping injectors today. hopefully thats the problem.
          • dude8383
            • Jan 2005
            • 10387
            Tps?
            • bloodshot-e30
              • 1494
              compression??
              ^Back in the game^
              BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
              FS thread:
              http://www.r3vlimited.com/board/showthread.php?t=214105
              • Dj Buttchug
                • Jun 2010
                • 7678
                try AFM too. it may need to be taken apart cleaned and adjusted
                watch vid
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • B-well
                  • 1042
                  PROBLEM SOLVEDDD!!!
                  Bad fuel injector and the rest clogged.
                  Purrs like a kitten now. thanks to all
