Simon's take on: 'Mess Under the Intake'
  • Vivek
    attention whore/retard/bitch
    • 6167
    #46
    Originally posted by Ryann
    The idea that hardware store doodads and driveway engineering can somehow out-smart the Germans seems hilarious to me. If you'd like to bypass the TB heaters you can do so with the existing factory hoses.
    Simply replace what's leaking, leave what's not, and enjoy the factory drivable experience.
    There's almost no reason to have a heater plate on the throttle body.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • M3Philipp
      • Jul 2011
      • 278
      #47
      What is the reason for the throttle body heater plate?
      I think I have asked before, but simply I did forget it.
      And by the way, I have never seen an 318is here in Germany, that uses or has the heater plate from stock.
      While at the same time, many US 318is seem to have it.
      • roguetoaster
        Biggus Tippus
        • 7829
        #48
        I suspect the idea was to raise intake temperatures for emissions compliance. Perhaps it has to do with prolonging the life of the catalytic converter or heating it up faster since most European M42s did not have them.
        I think I have read elsewhere that it was to prevent icing, which I don't think it correct as the coolant would be cold and as you say European M42s don't have the system.
        There was also a similar feature on my 16v swapped GTI, except it was a temperature controlled switch that moved a plate in the filter box causing air to be drawn from the engine bay instead of the snorkel/outside air system.
        • bats
          • Jan 2008
          • 128
          #49
          Great write up Simon.
          I'm wondering about the Heater Core hoses.
          Originally posted by Simon S
          23 1 64211386691 Return hose (from core) 27.84 27.84
          24 1 64211386690 Inlet hose (to core) 21.88 21.88
          Do these hoses eliminate the need for the bypass valve (for the Heater Core)?
          • Simon S
            • Oct 2004
            • 3758
            #50
            Thanks.
            The bypass valve and associated bypass valve hoses are spliced into the stock heater core hoses.
            To answer your question, new heater core hoses do not “eliminate the need”. The choice to install a bypass valve is up to you.
            Per answers given in this thread, the bypass valve is a thermostat that closes off flow to the heater core in the event of elevated coolant temperatures. If you’re not worried about overheating your engine/coolant system, then I wouldn’t worry about installing the bypass.
            If you get new heater core hoses, install them as is to eliminate bypass valve - or cut them in appropriate spots to incorporate bypass valve.
            Fwiw, here's a RealOEM link to the "thermostat"/bypass valve parts and plumbing:
            http://www.realoem.com/bmw/showparts...35&hg=64&fg=99
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            • unevolved
              • Nov 2011
              • 714
              #51
              Why would the bypass close off the heater core if the engine's overheating? Wouldn't you want as much heat transfer as possible?
              When I used to work at a driving school in college, the only way we could get the Miatas to stay below about 215F was to run the heater when it was real hot out.
              1991 318i SOLD
              2003 325i SOLD
              Racecars and stuff.
              • Simon S
                • Oct 2004
                • 3758
                #52
                Ha. Good point.
                The way I understand it - the heater core/valve under the dash can be a weak point over time.
                When it fails, coolant may spew into cabin and on the driver’s leg.
                I believe the ultimate purpose of the bypass valve is to prevent a core/valve failure w/in the cabin.
                • bats
                  • Jan 2008
                  • 128
                  #53
                  Thanks.
                  Thanks, I ended up figuring out the reason hot coolant was not flowing was because the bypass valve was blocked (old cruddy coolant) beyond repair. Purchased a new one and voila, I have heat in the vents.
                  • djmossm42
                    • Jul 2012
                    • 687
                    #54
                    Here's the recall notice for the TB from my insurance
                    Recall Number: 91V219000
                    Dates Manufactured: JUN 1990 to NOV 1991
                    Number of Vehicles Affected: 15200
                    Date Owners Notified On: JAN 0001
                    THE CRANKCASE VENTILATION SYSTEM, VENTED INTO THE INTAKE TRACT OF THE ENGINE AT THE BELLOWS BOOT AHEAD OF THE THROTTLE HOUSING, ALLOWS WARM WATER VAPOR FROM THE CRANKCASE VENT TO CONDENSE AND FREEZE IN THE COLDER BELLOWS BOOT WHEN THE AMBIENT AIR TEMPERATURE IS 15 DEGREES FAHRENHEIT OR LESS. THE BUILD UP OF ICE CAN DISLODGE AND MOVE INTO THE THROTTLE HOUSING, PREVENTING THE THROTTLE PLATE FROM FULLY CLOSING WHEN THE DRIVER RELEASES THE GAS PEDAL.
                    Consequence of Defect:
                    IF THE THROTTLE PLATE IS PREVENTED FROM CLOSING, THEREIS AN INCREASE IN IDLE SPEED AS WELL AS SLOWER THAN NORMAL DECELERATION, WHICHOCCURS WITHOUT PRIOR WARNING AND COULD RESULT IN AN ACCIDENT.
                    Corrective Action:
                    REPLACE THE THROTTLE HOUSING WITH A VERSION CONTAINING A MODIFIED HEATING SYSTEM ALONG WITH REROUTING OF THE CVS HOSE. THIS WILL PREVENT ICE BUILD-UP IN THE INTAKE TRACT.
                    So if you don't live in an area or travel to places that reach below-freezing temps removing it is fine.
                    Heres' the recall for the Heater Core
                    Recall Number: 93V015000
                    Dates Manufactured: JAN 1983 to JAN 1993
                    Number of Vehicles Affected: 375000
                    THE MALFUNCTION OR FAILURE OF A COOLANT SYSTEM COMPONENT RESULTS IN SIGNIFICANTLY INCREASED COOLANT TEMPERATURE AND A RESULTING INCREASE IN SYSTEM PRESSURE.
                    VEHICLES OPERATED UNDER THIS INCREASED COOLING SYSTEMPRESSURE CONDITION CAN SUFFER DAMAGE OR FAILURE OF PARTS OF THE COOLING SYSTEMSUCH AS (1) LEAKAGE FROM A COOLANT HOSE, (2) LEAKAGE OF THE RADIATOR OREXPANSION TANK, (3) DISCONNECTION OF A HOSE FROM A PIPE OR A FITTING, AND (4)CRACKS IN THE HEATER CORE END PIECE RESULTING IN COOLANT LEAKAGE. IN SOME CASES,BOILING COOLANT CAN CONTACT THE LOWER RIGHT LEG OF THE DRIVER RESULTING INBURNS. ALSO, ESCAPING COOLANT IN THE PASSENGER COMPARTMENT CAN CAUSE VAPORFOGGING OF THE INTERIOR SURFACE OF THE WINDOWS, REDUCING DRIVER VISIBILITY.
                    Corrective Action:
                    DEALERS WILL INSTALL A THERMOSTATIC BYPASS VALVE IN THE ENGINE COMPARTMENT TO CONTROL COOLANT TEMPERATURE IN THE HEATER CORE. ALSO, A NEW DESIGN RADIATOR CAP WILL BE INSTALLED, TO CONTROL PRESSURE AND PROVIDE GREATER COOLANT OVERFLOW IN THE EVENT OF OVERHEATING.
                    Wheelwell
                    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
                    LED Bulb Thread
                    R6 LED Review
                    • Simon S
                      • Oct 2004
                      • 3758
                      #55
                      Cool.
                      Thanks for that contribution. Good stuff !
                      • bsturman92
                        • Sep 2012
                        • 282
                        #56
                        hey guys. so i had just ordered all the parts needed to do the mess. now i have one quick question... i want to do silicone hoses for all my vacuum lines because i dont wanna risk any hoses collapsing.. do you think this would be a good idea? any help is appreciated
                        • Simon S
                          • Oct 2004
                          • 3758
                          #57
                          meh.
                          Like you could and all but it's just a whole lot easier to buy/use OE parts since they're all pre-shaped.
                          It's not like I worry about them ever collapsing..
                          • unevolved
                            • Nov 2011
                            • 714
                            #58
                            Yeah, I mean, it won't hurt, but it isn't exactly necessary.
                            1991 318i SOLD
                            2003 325i SOLD
                            Racecars and stuff.
                            • bmwman91
                              • Oct 2004
                              • 3134
                              #59
                              The hoses won't collapse. They crack & give you awesome vacuum leaks to chase, but they don't collapse lol.
                              Transaction Feedback: LINK
                              • bsturman92
                                • Sep 2012
                                • 282
                                #60
                                really? i was doin alot of reasearch on m42club and e30tech and heard if a few people having there hoses collapse on them. idk if they were using weak or improper hoses or what but i thought i would ask before i went ahead and ordered it all... but i had just got 5 feet of silicone vacuum hose from a customer of mine who has his own shop! so i guess im going that route. cant hurt and shit it was free.... no complaining here! but now i cant decide whether or not i want to delete all the coolant relief hoses or not. that picture you posted of urs simon looks clean AF. i love it. but f$%* having a chance of hot coolant spilling on my leg.... im not tryin to bring up that discussion for everyone to have again but i really wanna get rid of em just because of how clean it looks lol
