M42 Pilot Bearing
  • io_RobbieRodgers
    • Nov 2011
    • 57
    M42 Pilot Bearing
    The M42 does use a pilot bearing, right?
    I'm getting to the end of my rebuild, and for the life of me I cannot recall a pilot bearing falling out when I pulled the crank out, and there's nothing inside the flywheel. I would have known if my car was running without a pilot bearing, right? It's kind of necessary, yeah? I hope to God I don't have to tack on another week to this waiting for a bearing to come in the mail.
    Complete writeup of rebuilding the M42 is in the works, for those interested.
    Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
  • io_RobbieRodgers
    • Nov 2011
    • 57
    Also, how bad of an idea is it to not use a torque wrench when putting everything back together, and guesstimating torque values? This may be a moot question, but has anyone had disasterous results?
    • Dj Buttchug
      • Jun 2010
      • 7643
      yes a pilot bushing is used and no it probably didnt fall out of the crank. To best answer your question you do need one... and no. guessing torque values isn't a good idea, especially on things that spin very fast, like flywheels...
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • StereoInstaller1
        GAS
        • 22679
        Get a harbor freight torque wrench at least. On the M42 we are in the middle of building, the pilot bearing DID fall out when we pulled the clutch off the flywheel.
        Closing SOON!
        Thanks for 10 years of fun!
        • Ryann
          • 3350
          My clutch kit came with a pilot bearing, not a bushing. Are you really getting to the end of an engine rebuild without a torque wrench??
          • io_RobbieRodgers
            • Nov 2011
            • 57
            Well, there's my answer. Going to HF tomorrow and checking the torque values of the crankshaft.
            • io_RobbieRodgers
              • Nov 2011
              • 57
              Well I checked the values of the bolts today, look like they're all torqued to around 30 Nm, which is 50% more than the 20nm the torque manual specifies. What's the consensus? Do you think the bolts could be compromised?
              • AndrewBird
                The Mad Scientist
                • 11898
                Which bolts exactly are you talking about? The ones that hold the flywheel to the crank?
                If so, it shouldn't be a problem. You are only talking 7 ft lbs extra, which is not much. It's more important that they are tightened equally and not too loose. I would loosen them all back up and re-torque them correctly.
                • xwill112x
                  • Jan 2009
                  • 4236
                  Always do your tq #'s correctly or you will regret it when rdore comes into play.
                  • io_RobbieRodgers
                    • Nov 2011
                    • 57
                    I was talking about the rod bolts to be more specific.
                    • aka-e30
                      • Jul 2011
                      • 15
                      yes 100% rod bolts need to be torqued correctly. If i were you i would just back them off and re-torque them. 7ft/lbs isnt going to strech the bolts any. I take it you still have the engine out of the car? Or havent run it yet?
                      • Massimo
                        • Jan 2008
                        • 3207
                        This is what happens when flywheel bolts come loose.
                        IDK how you think it is ok to estimate torques on an engine rebuild.
                        • Victell
                          • 1081
                          ^^ those bits have also been known to go through the front driver and passengers' lower legs. Ouchie.
                          • Dj Buttchug
                            • Jun 2010
                            • 7643
                            holy fuckkkkkk
                            Ig:ryno_pzk
                            • Massimo
                              • Jan 2008
                              • 3207
                              Yes. I think it is a 300zx. I recon the guy is luck to still have toes.
