skid plate?? how low??
  • immajackuup
    • Dec 2010
    • 1132
    How low can yall go with these m42 skid plate with out scrapping the shitz out of it????
  • flash 23
    • 904
    depends how low u r. if youre on ie3 and drophats then about 3" ymmv
    • immajackuup
      • Dec 2010
      • 1132
      i c,guess 2inch is a ok clearance.
      • e30nub
        • Jun 2008
        • 1741
        I was dropped on FK 60/40's with Bilstein Sports which brought my skid plate 2 inches off the ground. I broke an oil pan through the skid plate (unknown concrete object obliterated my plate and pan), and have since raised my car back up to stock. Personally, it's not very fun to daily drive a car that is 2 inches off the ground. If it were my weekend car, it would be an inch off the ground. ;)
        Pictures for reference:
        -Pierre
        1987 535is
        1988 325is
        • trackjunkie21
          • Jan 2010
          • 3962
          It's because you have the wrong skid plate;)
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • immajackuup
            • Dec 2010
            • 1132
            then what skid plate do you have?^^^ because i have the same one as e30nub.
            • 619E30
              • 1753
              Peerless Skid Plate is much stronger, and I believe sits a bit higher?
              Originally posted by audiquattrot
              bimmers b4 b*tches....remember that.
              1990 Alpinweiss 325i - secret 500whp build
              2000 Audi S4 B5 Laser Red
              1990 Nissan 240sx - Drift Missile
              2006 CBR600RR
              • immajackuup
                • Dec 2010
                • 1132
                is it plug and play or does it require welding???
                • Slowpoke
                  • 36
                  I believe it requires welding:
                  • flying_violin
                    • Jan 2011
                    • 325
                    The e30motorwerks one does require welding. Speaking of which, I need to weld mine on at some point!
                    Alpine II 318is
                    • irish44j
                      • 2763
                      lol
                      Stage rally/rallycross e30 build/competition journal
                      Track/street e21 build
                      visit Condor Speed Shop
                      visit Motorsport Hardware
                      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                      • immajackuup
                        • Dec 2010
                        • 1132
                        what is that^^^ home made skid plate?
                        • irish44j
                          • 2763
                          yeah, it's my test plate in 14ga stainless, still in the works, that pic is just a test-fit. Will eventually built one in 10ga with more substantial backing, but this will do for the moment. The car is for rallycross, on tall springs and minue 300lbs of weight, hence why it sits so tall (intentionally).
                          The one in the pic above I just built yesterday with garage tools and scrap material. Once the fit and cuts are perfected, I'll have a thicker piece laser-cut and press-bent.
                          (also, it's on an M10 318i - I just posted it here because I was browsing and thought it was funny I had the same picture angles as the guy above with the low car)
                          link in my sig has my build thread, with more pics of the skid, etc...in case you're interested.
                          • KenC
                            King of Kegstands
                            • 14396
                            If you break a pan through a Race Skids plate you motor mounts should have been replaced. The hydraulic ones sag over time giving hardly any flex room.
                            Originally posted by Gruelius
                            • 3bvert
                              • 1032
                              agree
                              when I first put my plate on I had near a 1/2 inch between the oil pan and the skid plate
                              after about a year or two I noticed ( last month while doing an timing chain replace) that my oil pan was on my skid plate, it was not that the skid plate had bent up, its my mounts had dropped down
