Clutch Replacement: The Aftermath
  • LoneWolf
    • 402
    Originally posted by Jboss12
    So far I'm not sure what the plan is. I got an amazing deal on Craigslist that I couldn't pass up. The clutch was gone when I bought it so I was just going for the cheapest path to get it up and running Without going over what I paid (i dont need it running asap, i have a dd e36). I got rid of the a/c when I did all the timing components. It's a convertible so I figured what the hell.
    What sort of benefits would the lightened flywheel give me besides the obvious weight benefit?
    Faster revs and quicker deaccel.
    Would make the car feel more alive. I am looking to do it.
    Seems the only way to get the benefit and actually shave some weight would be an aftermarket flywheel
    • immajackuup
      • Dec 2010
      • 1132
      So I found the easy way for me. They have a thread in this forum. here, dynotech motorsports
      emailed
      www.dynotechonline.com
      complete kit ran me $535
      12 lb lightened M20 flywheel (with M42 starter ring gear)
      325 clutch kit
      shorter flywheel bolts
      longer slave cylinder push rod
      They have the all in one solution and cost wasn't bad in my book.
      :D
      • 3bvert
        • 1032
        emailed
        325 clutch kit
        :D
        http://www.m42club.com/forums/showth...?t=5696&page=3
        i like it
        • Learning
          • Feb 2011
          • 70
          Hi,
          While I was driving, my clutch pedal had no pressure/resistance at all and so I couldn't shift the gear. When I depressed the clutch pedal, it dropped with no resistance to the floor. Went to mechanic and he said it was the master and slave cylinders needed to be replaced. He replaced them, but problem persisted and he then also replaced the clutch plate. I got the car back and drove for 6 days, but suddenly, while driving on a street, I couldn't switch the gear and so I had the car towed away back to my mechanic and this time he said it was some wire/cable connected to the clutch that broke. What are your thought guys? I don't want to be fooled around my a mechanic.
          From the beginning, perhaps the only problem was only a broken wire/cable connected to the clutch pedal.
          • davem
            • Jun 2010
            • 705
            Originally posted by Learning
            Hi,
            there isn't any cable/wire - the clutch uses hydraulics. The clutch pedal is hooked up to the clutch master cylinder. If one of your clutch lines failed I'd be pretty pissed because the tech should have inspected them while replacing your slave and master cylinder.
            • Jboss12
              • 357
              emailed
              325 clutch kit
              :D
              Wow that's a great deal. I just wish I had the funds right now. I guess having a project car while youre a broke college student isn't the best idea. I think I'm just too addicted to these cars haha. I have another dual mass that's in really good condition that I'm gonna put back in.
              Thanks for the good info. I bookmarked that site for future use
              Agreed. That seems to me like a pretty big mistake
              • immajackuup
                • Dec 2010
                • 1132
                Hi,
                find a new mechanic because he doesn't know shit.
