M42 fotostory, as requested
    The hoard before the storm :) FYI, a lot of this stuff came from fellow r3v members
    I started with a 5/95 M42 from a 318ti. Lighter valves (6mm), no idler gear for timing chain. Then added...
    3 angle valve-seat grind, barely decked
    Metric Mechanic (MM) Valve Springs/Guides/Retainers
    M44 +.50mm pistons
    VW Hydro lifters
    M44 Crank (no timing gear = weight added to balance out)
    M20 Single-Mass 13.5lb flywheel (swapped M42 ring gear onto it)
    Late M42s came with lighter M44 rods (both are 140mm long)
    Block was bored. Align-honed mains. Assembled with ARP head & main studs, M44 head gasket, Total Seal rings.
    MM Single-Row timing chain
    Unknown specs on re-ground stock cams (got them on the cheap from hqautosport)
    Luke Box and M44 electric rad-fan in the background...
    Covering the goodies up with a little black dress from theButcher
    Crown Jewel
    Attempting to keep the ITBs clean with this custom catch-can
    Bosch Design 4 24lb/hr injectors w/EV14 to EV1 adapters = plug n play
    Using TunerPro RT and Ostrich 2.0 for DIY tuning
    Got custom XDF from Midnight Tuning (bmwconnect on M42club), specifically for the 24lb injectors
    KnockLink G4 for detonation detection, can't let my noob tuning destroy all the hard work ;)
    LC-1 Wideband (one of george's button gauges for bling/stealth factor)
    Once I get it tuned on the AFM, the SplitSec MAF kit I got from Julien should help the ITBs breathe easier
    E30 318i(s) specific cat-back from fox exhaust
    Non-M42 content...
    3.64 Torsen Diff, Nobody knows what they have $375 shipped (eBay)
    A set of barry's rebuilt half-shafts
    M3 Cluster to support higher r3vlimit (Schneller 3er)
    TRM tuning oil-distribution block for M3 temp sender and VDO pressure sender/switch
    E30 M3 GC Coilovers (Schneller 3er)
    Staggered M System 2s (getting fresh powder-coat a la White325is)
    Hell yeah!
      Awesome work! Those GC's look awesome in that powder color.
      alexw
      (2) E30 tourings - sold, E30 M3 - sold, 89 325ix sedan, 91 318is slicktop
      Wisconsin Members!- Join WiBimmers.com, Wisconsin's BMW community.
        Looks good dude, had no idea you were so far along. BTW sorry for wakin' ya up. Keep up the good work.
        -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
          Thanks! I can't wait to pick them up from GC and see how they look on the car, lol... (stance much?)
          No worries man! It's just a growing pile (or 2) of parts right now, but I'm taking a month off when I get home and a lot of that will be spent working on the E30 ;) I reserved a Z4 coupe and 6 laps around the ring for this Sunday (there will be pics 8)) The tires are off and ready for you and I will check my APO again when I get back from Rome.
            Make sure to take plenty of pics at the 'Ring and in Rome.
              Nice! This is going to be bad ass.
              Hadn't heard of that cat-back setup prior to this post, looks hot.
                Sub' for future awesomeness
                  yeah more info on the exhaust be awesome
                  Sometimes better...Isnt really better.
                    Never knew this!!! Is that what your engine had when you pulled it apart and is there any literature on this?
                    Leo.
                    E30 318iS, E36 328i
                      I got it on ebay.de, from these guys: http://www.ebay.com/itm/FOX-AUSPUFF-...item3a704f2b57
                      the manufacturer's website is www.fox-exhaust.com/us but it looks like the don't have any US distributors yet. once I have it installed I'll post a video. I think I offered them like 550 euro shipped.
                      Yes, I discovered it when tearing the engine down.
                      you can confirm this on www.realoem.com if you pick a 5/95 318ti it will offer you the option of M44 or M42 engine, it was a crossover year.
                        Wow. I remember your post on m42club about the exhaust but totally missed your build thread. This is amazing stuff!
                        Any reason why you chose the m44 rotating bits vs picking up an m47 crank? Easier to source?
                        Need OE BMW or Aftermarket Parts? Shoot me a PM! | Leave me feedback here
                        info@omgmotorworks.com
                          Great build. Looking forward to hearing more. Would love to see a dyno sheet when you are finished.
                            Originally posted by dude8383 View Post
                            Easier to source
                            this
                            Thanks, i can't wait to get home and basically rebuild the whole damn car. There will def be lots of pics and a dyno run. There's a tuner local to me with a dyno that welded in my adjustable rear subframe bits.
                              Thanks for getting back to me on this - that was a perfect, simple, clear and concise answer. You are a champion!
                              Leo.
                              E30 318iS, E36 328i
