bouncing gauges on the dash
  • chrisbmwe30
    • Jul 2011
    • 61
    my 1991 e30 318is has a problem with the tacho not responding and the speedo jumps up above 45km/hr and begins to read but will drop at any given time. also the temp gauge bounces not like an increasse of coolant temp but bounces back and forth a little very quickly, i have just finished a complete rebuild of the motor and installed all new temp sensors so that rules that out for why the temp gauge bounces. where are all the speed sensors speedo cable are and how to check there operation. this problem was also present before the motor rebuild.
    thanks
  • Dj Buttchug
    • Jun 2010
    • 7677
    is the battery dead? or dying?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Jboss12
      • 357
      I'm not sure why all of them are bouncing but I remember when my speedo was messed up it was because of the sensor that plugs into the diff. It was all covered with gunk. When I was driving on the freeway it would randomly start bouncing up and down then stop working all together. This is for an e36 though but I'm pretty sure they have the same location for the speedo sensor
      Either that or what buttchug said
      • bmwm42
        • 6300
        Crappy board replace cluster
        Originally posted by bmwm42
        PNW vulture pm me for parts
        Strategic nw e30 command
        • nomansland92
          • 1657
          Mine did this with the temp gauge when the group was bad.
          Check all the connections before you buy anything
          IX being restored here
          Ix turbo build here
