318is Manual trans fluid
  • VANOS714
    • Nov 2011
    • 1195
    any one has any recommendations on trans fluids? can you actually put in axle fluid? I was looking at 75w90 synthetic axle fluid will that work?
  • drumad
    • Aug 2009
    • 1700
    In my g240 I used Redline ATF D4.
    It depends what the sticker on your tranny says. It may take 75W90 or it may like ATF. Take a look.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • VANOS714
      • Nov 2011
      • 1195
      thanks for the feedback. I'll take a look when i put the car up on the lift.
      • Dj Buttchug
        • Jun 2010
        • 7688
        no. all late model g240 transmissions take ATF. none take gear oil that I have ever seen. ever.
        you can also run castrol import ATF fluid. it can be found at any local auto parts store. its cheap and works well. I run it in both my daily and my turbo car. both shift smooth, no problems to report
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • drumad
          • Aug 2009
          • 1700
          Poop, probably should mention that the sticker thing applies to the g260s.
          2008 335i - n54b30
          1991 318i - m52b28
          • Dj Buttchug
            • Jun 2010
            • 7688
            ^ did not know that 260s run on gear oil... interesting
            Ig:ryno_pzk
            • drumad
              • Aug 2009
              • 1700
              Here's a good thread.
              2008 335i - n54b30
              1991 318i - m52b28
              • jrobie79
                • Mar 2006
                • 2526
                I use Redline MTL, no issues
                1991 318i ---- 308K - retired
                • Ryann
                  • 3350
                  Same here. I have noticed though that when it's cold outside this stuff needs to warm up a little before the shifts get really sweet.
                  • M3Philipp
                    • Jul 2011
                    • 278
                    318is.
                    For the gearbox, use a GL4 Oil.
                    For the differential, a GL5.
                    • lbreevesii
                      • Aug 2009
                      • 412
                      It calls for ATF. A lot of people have used 75w-90, or MTL, but i'm a bit leery of it. I put in 1 qt redline D4 and topped it off with some leftover mix of redline MTL and MT90. Works brilliantly. no issues in the cold, hot, etc and its got 220k on it.
                      I don't always wreck cars, but when I do I wreck them into trees.
                      91' 318is S50 swap - The Black Widow
                      • goinstrong
                        • Jul 2008
                        • 215
                        I have ATF in mine...works well...
                        Tim
