Is putting 92 in your car good for our small engines or bad I've heard both
M42 Chit Chat Thread
Transaction Feedback: -click here
[e30: '91 318is coupe|brilliantrot||e36: '98 318ti|fern green|California top|M-Tech]
[URL="http://www.r3vlimited.com/board/showthread.php?t=300453"]
last i checked you should be putting premium in it. i guess 92 is the highest in your areaDENY IGNORANCE!
Schwarz 325-totaled
brilliantrot 318i-daily
Originally posted by mkcman17don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
Originally posted by Roysneon View PostHow much endplay is OK? I have enough to hear a click from the crankshaft when I pull and push on it. The engine is completely stripped to the rotating assembly. I know an M50 thrush bearing is a good idea but damn, I just bought every single gasket and seal new and just wanted to reseal the damn thing and swap it in.Originally posted by Grueliusand i do not know what bugg brakes are.
FML. Thanks for the clarification, Ken.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.
Originally posted by Gerta View Postken - Is it as simple as swapping a crankshaft or would that be a whole bottom end rebuild?For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.
Didnt want to start a thread on this, but I installed a pair of Silences solid trans mounts on my car....
Absolutely undriveable on the street. NVH is hilariously retarded. You have to basically yell at you passenger to hear each other, and my car was fairly quiet before I installed these.
However, they did firm up the drivetrain a good amount, and shifts feel nice. I'll save them for when the car becomes a dedicated track car.
-NICK
I have them for my soon to be M50 swap. I've driven rough/stiff/solid mount cars before, I'm hoping these will be OK...For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.
Here's one for all of you M42 lovers. I experienced a highly unusual set of occurrences when installing a replacement cylinder head; one, the cam lobes at the front of the engine were pointing up at each other, cam squares were locked at the rear, TDC 1 double checked with simple screwdriver method; 2 cam sprocket bolts centered in slide slots; three, vibration dampener off 4 (or was it 6 I cannot recall) teeth!!!, even removed dampener to make sure keyway was still intact; four, flywheel locked at TDC 1; five, turned engine over many times by hand, pulled out hair, cursed repeatedly, buttoned engine up and turned it over with fingers crossed and bated breath; six, engine ran fine and has plenty of power; seven, shut car off, said "Oh well," left it alone. My assumption is that somehow the the flywheel is misaligned and that there is an issue with the alignment of the block arrow and the dampener. The car has been running fine for thousands of miles like this BTW. So, am I lucky, stupid or do I just have a weird car?
