Going from m10 to m42
  • gemini325es
    • Dec 2008
    • 4
    Hi I got a slamming deal on a m42 engine and wiring harness. I wanted to know of this swap has been done before. I have a 84 318i 5spd and wanting to swap in the m42. How difficult is this. I'm familier with wiring and such. Wanted to know if there was a write up some where of someone doing it documenting what was done. Thanks.
  • willworkfore30s
    • Aug 2011
    • 1090
    Its been done about a million times in 2002's. I would check out some of their forums
    • timofeylbelarus
      • Dec 2010
      • 326
      i have done it for a buddy of mine
      1985 325e - wrecked :( (being fixed and full paint job)
      http://www.r3vlimited.com/board/showthread.php?t=197989
      the horrible day
      http://www.r3vlimited.com/board/showthread.php?t=210850
      1991 318i - in process of being made a DD
      http://www.r3vlimited.com/board/showthread.php?t=219793
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I will be doing this swap in a 2002 soon.
        • Link
          • May 2012
          • 834
          Anymore info on this? This is exactly what i am hoping to do.
          View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
          • twistednut
            • Nov 2007
            • 272
            I've got the driveshaft with a good pre-87 CSB needed for this swap.
            what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
            • Unearth078
              • May 2008
              • 2623
              whut? his drive shaft should be ok, and if not he would still need the m42/g240 d/s from post 90...
              Originally posted by Lof8
              4 doors allow you to transport more whores.
              therefore, their value is much greater.
              Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
              • twistednut
                • Nov 2007
                • 272
                Just to clarify, pre 87 CSB's have a different bolt pattern than post 87'. The driveshaft I have is a 91' 318is, with a good CSB, that was used on a 84' 318 with a m42 swap.
                • TobyB
                  • 5296
                  9 of 87, it turns out- my 2-87 has the early tunnel...
                  t
                  • TobyB
                    • 5296
                    oh, and search 'c-101' for a lot of helpful stuff on splicing a body harness to an engine harness.
                    You DID get the engine harness and ECU, right?
                    (If I had it, I'd swap the body harness too. Probably take only a bit more time than
                    splicing, and 1/10 the aggro. Plus, you'll find $5 in loose change while you're in there.)
                    t
