My 91 318i kind of sounds like a diesel when running
  • 90pioneer
    • Jul 2011
    • 78
    I just bought a 91 318i. It sort of sounds like a diesel when it runs/drives. It has 178k on it.
    Would this be from exhaust? It doesn't seem rusted out, or would it more than likely be from the timing chain tensioner piston?
  • mr ilia
    • May 2011
    • 582
    It is likely a chain tensioner issue. My does the same only during a cold start and only for a second or so.
    • xoneslosentrax
      • 407
      u are having the same problem as i am..look at my post and watch my video and see if it does sound like it..i took the tensioner part and its pretty much fucked..
      • bmwman91
        • Oct 2004
        • 3134
        It's the tensioner piston. Replace it now for $40 & 5 minutes of work, or spend $600 on parts and 20 hours fixing the damage later if you don't!
        Transaction Feedback: LINK
        • Gerta
          • Sep 2009
          • 2119
          ^ This. Solid advice here boys ... do it now or pay for it later.
          Parts Collector and Former Houndstooth interior junkie.
          • hyperE30
            • Sep 2009
            • 2202
            yes indeed, happened to me but I had to replace timing guides too and so and so!!
            fix it nao!!
            HyperWerkz
            89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
            " enjoy the show "
            • smyleboyd
              • Sep 2011
              • 1164
              I need to put this one on the list. im getting the "diesel" noise aswell at 183k. i have a feeling that my chain is not in the best shape :/
              • xoneslosentrax
                • 407
                I just ordered my tensioner
                • thebutcher37
                  • 2877
                  Hmm now school is out I want to do this.. Any write ups?
                  • Ryann
                    • 3350
                    How many times is this going to be covered before people wake up and search??
                    This sub-forum is in desperate need of some stickies.
                    • xoneslosentrax
                      • 407
                      hahaha i know right...there a few write ups on it but they havent been stickied yet..dunno y
                      • EN318isPDX
                        • Oct 2007
                        • 4373
                        He speaks the truth, I let my tensioner go and it took out most of my guides. 300 dollars and hours of work later. Wish I had fixed the tensioner sooner
                        "If your timing chain tensioner is more than 4 years old you should replace it too"
                        I let mine go for 8+ years and paid the price
                        • mr ilia
                          • May 2011
                          • 582
                          Simple, take a 19mm wrench, find a bolt that fits this wrench size....it is located on the engine block, just above the a/c compressor.
                          One the bolt out, replace the inside part with the one you already received from your BMW parts supplier.
                          • thebutcher37
                            • 2877
                            Ohhh... I thought there was more to it!
                            thanks for pointing it out.
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              Desktop Dave from M42 club advocates caution when replacing a tensioner in an unknown condition timing gear setup. I would suggest that you start saving for an entire timing gear/chain overhaul, if you want to keep the car that is. Also, be sure to read up on installing the piston, I cannot remember if it is to be installed compressed or extended, and what the break in procedure is exactly.
