Help! Won't start after timing job
  • bstarr3
    • 170
    Some background: I've been having some overheating problems. After ten to fifteen minutes of running it would start to nudge over half then eventually keep heating up. Twice last week it got to between 3/4 and red line and was there for a few minutes (maybe 5) before I could get off the road.
    I needed a timing refresh anyway so I planned to replace water pump and thermostat in the hopes that one of those was the cause of my problem. So I just finished that job and now I cant get it to start.
    Description of symptoms: when I try to start I can hear to starter, it sounds like its trying to turn over, then an abrupt 'clunk' and a visible jolt in the engine.
    I've given up for tonight, but I need to make sure that plugs and coils are all plugged back in in the proper order. I can turn the crank by hand, which I hope means that its not hydro locked, which is the number one thing I'm afraid of given the history of overheating.
    Any other ideas of what could be causing this problem? Steps I could have done wrong or missed in reassembling the engine? Simple solutions, like a sensor wire or something?
    Please help. Thanks
  • bstarr3
    • 170
    Edit: I've confirmed that the plug wires are properly routed. Same thing.
    Here's a video:
    Sent from my XT912 using Tapatalk 2
    • JTapper
      • Sep 2009
      • 847
      The video is set to private.
      Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
      • bstarr3
        • 170
        Fixed. Can't seem to get it to embed in the post. But the link works now. Thanks for any help, and Happy Father's Day to you dads!
        • bstarr3
          • 170
          My next thought was that maybe I have the timing way off. As far as my limited understanding goes, everything looks right. Pictures:
          Cylinder 1 can lobes pointing upward and towards each other
          Cam sprocket arrows pointing up perpendicular to edge of timing case
          Cam 'blocks' square with each other and parallel to edge of timing case
          Harmonic balanced lined up with arrow on oil filter housing
          Flywheel locked at tdc
          Note on this last part: the tool doesn't really slide in to any hole but it catches at this point which corresponds to tdc according to all the other measures.
          Does this all look right?
          • Dj Buttchug
            • Jun 2010
            • 7688
            the crank is wrong. thats not tdc
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • Dj Buttchug
              • Jun 2010
              • 7688
              this is correct crank position
              hope and pray to the m42 gods that you didnt bend valves..
              Ig:ryno_pzk
              • bmwman91
                • Oct 2004
                • 3134
                Yup, the little arrow on the filter housing needs to point to the "notched" damper wheel tooth. It's hard to see on a dirty motor. Keep your fingers crossed that things are still in proper order!
                Transaction Feedback: LINK
                • blackhawkimpact
                  • 2415
                  Looks like you're way off
                  • bstarr3
                    • 170
                    Okay, shit. What is the proper way to align it correctly, assuming I haven't bent valves? I want to mitigate the damage at this point and get it back running.
                    How will I know if I've bent a valve? Will it not start, or just make a god awful noise?
                    • bmwman91
                      • Oct 2004
                      • 3134
                      If valves are bent, it will run really poorly, and probably give some backfiring. I am not sure how you got the crank damper to look misaligned if you had the pin in the flywheel, unless you have had the flywheel off, the alignment sleeve was missing and bolted it back on in the wrong orientation.
                      Did you forget to remove the flywheel lock pin when starting it?
                      • bstarr3
                        • 170
                        I took the flywheel lock out before starting it. Maybe I didn't have the flywheel locked properly when I locked the cams? I'm going to turn the crank until its lined up tdc and see if the flywheel lock works there. Then I'll move the cams to match?
                        Also if the valves are bent is running it long enough to pull it onto a truck going to destroy it?
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          no the op said that the lock pin wasnt sliding into the specific hole. it was just catching on something??
                          That big clunk you heard was probably valves kissing pistons. You cant really mitigate anything, the damage is already done if there was contact. The only thing I might bank on would be the fact that cranking a piston up into some valves could be less destructive than burning air fuel mix and forcing one into valvetrain.
                          I dont think you could have had the flywheel locked in that position at all. Theres no way it would line up. I think the op just made a mistake on where the timing mark actually is on the HB??
                          Ig:ryno_pzk
                          • M3 Ryan
                            Site Sponsor
                            • 2298
                            If you cranked it like that then the valves may be bent. I had an m42 last week that broke a guide and skipped timing 2 teeth and it bent all the intake valves. Had to remove the head and replace the valves and chain/guides. Not a cheap job. You might have had a bad head gasket anyway if it was overheating before.
                            '88 M3.2 S54 Lachssilber/Black
                            '07 335i Alpine/Black Sedan
                            '12 X5 3.5i Alpine/Black
                            iS Splitters For Sale, PM ME!
                            • bstarr3
                              • 170
                              I don't know. The flywheel tool only comes close to engaging at the spot I pictured in the third post.
                              When I take the crank bolt off the hb spins freely on the crank even though there's a notch on it that goes to a tab on the crank. That, to me, explains how the flywheel can be locked but the notch on the hb looks wrong
                              Btw when the hb is spinning on the crank the crank and cams arent turning
