m42 crank bolt hate thread
  • genocide98
    • Oct 2009
    • 106
    Snapped 2 1/2" breaker bars and spit the flywheel pin out several times... bought the crank tool and hopefully things will go smoother.
    Fuck you, m42 crank bolt.
  • Tisoc
    • Jul 2011
    • 249
    Did you try the starter method?
    • bmwm42
      • 6300
      it isnt hard at all to remove that bolt. put car in 5 gear ebrake on pin in hole and break it loose ive never had an issue with them in all the cars ive had to remove them
      Originally posted by bmwm42
      PNW vulture pm me for parts
      Strategic nw e30 command
      • genocide98
        • Oct 2009
        • 106
        I didn't do the 'starter' method because I already broke two breaker bars.
        Two different impact wrenches didn't cut it, either.
        It took a 3/4" bar, 6ft pipe, and the crank holder tool to break it loose.
        • Massimo
          • Jan 2008
          • 3207
          Yours obviously was never torqued to the correct torque. lol
          Mine wasn't ithor I max my torque wrench out at 200nm.
          • bmwm42
            • 6300
            Mine had never been removed some are just stronger than others I guess;)
            • TobyB
              • 5286
              Mine too. Factory torque, it'd never been apart...
              t
              • Dj Buttchug
                • Jun 2010
                • 7686
                that much torque is not needed when you go to reinstall it. Do like 100lb-ft and a little dab of locktite.
                makes the shit twenty times easier to remove it later if needed
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
