M42 connecting rods.
  • ADCD875
    • Dec 2008
    • 115
    Rebuilding my M42. Totally stock spec with new pistons, balanced crank shaft, all valves, valve guides, 3 angle valve job, intake/exhaust ports cleanup, all new timing components, etc. But run into a snag, my builder said they ran into weird issue of 2 of the conn rods being weird and locking when installed. They installed them in different combinations and in different bores. 2 are fine but the 2 are not good. The engine was running fine. Have no idea how this can happen.
    Anyway, I am now looking to get a new set of conn rods. May as well, since I sunk into this far.. There are great Eagle rods but they are 5mm shorter than stock and will not work. Carillo rods are awesome but way too expensive at $300.00 a piece. How about Pauter rods? Anyone has any experience with them? They are 4340 forged rods and light weight with $790.00 for a set.
    Or, are there any other venues/options for conn rods?
    Thanks
  • Massimo
    • Jan 2008
    • 3207
    Dose not really matter I suspose. Any good after market rod is going to be a big step up from the stock rod. Have you looked at Arrow?
    Unless you are going over 8000 rpm or serious boost stock rods are usually fine. So for your application I would just consider getting some of the lightest rods you can get in your price bracket.
    • whodwho
      • Jun 2008
      • 1547
      Eagle - CRS5313B43D - Found a couple cheap places ~300
      Videos, Pictures, Tech tips, forum help, gallerys, links, faqs and a lot more on high powered cars. We have videos that will blow your mind away! Taking your Honda or Acura to the limit!
      Carrillo
      Arrow
      Pauter - PR-M50220480140
      Pistons, Rods, Rotating assemblies, Ford 2300, sport compact, B8, LS
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Dj Buttchug
        • Jun 2010
        • 7677
        remember stock rods are forged and pretty badass from the get go. I have a perfect set of 4 if you need some.
        Dont spend a shit ton of money on something that isnt going to change the build much or give you a significant benefit.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • TobyB
          • 5263
          Yeah, that happens if YOU DON'T KEEP THE CAPS WITH THEIR RESPECTIVE RODS!
          I did that once. I was 15. I didn't know shit at the time. But I learned...
          Of course, if you get undersized bearings by mistake that would do it too.
          But both of these things should be really easy for someone who DOES IT FOR A LIVING!!!
          And anyway, when you have a rod 'reconditioned' it guarantees the bore diameter.
          This smells fishy to me.
          But then, a lot of things on the internet do, now that you bring it up.
          t
          • ADCD875
            • Dec 2008
            • 115
            Originally posted by whodwho
            Thanks
            Eagle rods are great but they are 5mm short and will not work with stock spec pistons.
            Arrow and Carillo rods are great but out of price range.
            Pauter rods are good and their prices are not terrible with $790.00 a set of 4.
            Thanks.
            • ADCD875
              • Dec 2008
              • 115
              This is a professional machine shop and they keep everything together. That is one of the questions I asked in the beginning. They are meticulus on their work. They will try to test clearances once more with mains properly torqued down.. Maybe these engines require that?
              t
              • ADCD875
                • Dec 2008
                • 115
                Thanks man. I might need them. Can you pm with your price? I will find out Tuesday or Wednesday if I need them or not..
                • whodwho
                  • Jun 2008
                  • 1547
                  Originally posted by ADCD875
                  Thanks
                  Thanks.
                  Odd they list them for m40/42 but @135mm
                  This one lists them at 5.513, might have them verify??
                  http://www.ebay.com/itm/EAGLE-ESP-H-...b8e0e9&vxp=mtr
                  Or you could try the CXRacing ones, they are probably made at the same source but would have them size verified
                  http://www.ebay.com/itm/CXRacing-BMW...70249a&vxp=mtr
                  If the budget allows go for the Pauters, I just picked up a used set for my project :)
                  • Dj Buttchug
                    • Jun 2010
                    • 7677
                    pm sent.
                    Ig:ryno_pzk
