Well I am going to pick up a Dyno on Friday to have one in house....once it is up and running I will be posting dyno charts. Also will be fine tuning tunes and more development for the m42.
Interest in Bolt on Turbo kit?
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC -
Can't wait to see updates...joined R3V just for this thread.
Jake-email sent.'95 E34 540i 6 speed dd'd and tracked with mods
'88 E24 635CSI 5 speed dd'd and tracked with mods
'91 E30 318is 5 speed...soon to be turboedComment
Just made my order! I will post detailed pics of all parts I get, and of each stage of the install process. I have a friend with a DynoJet and I will do before and after with AFs with the basic bolt on kit.
I will track this car as well as dd it, and will give feedback on both.
Jake has been responsive, and very helpful and I am excited about getting this done (6-8 weeks before I install).'95 E34 540i 6 speed dd'd and tracked with mods
Any chance you may offer ecu tuning for normally aspirated m42s in the future?
Sent from my SGH-T769Comment
https://www.facebook.com/ClassicDailyLLCComment
So a question a bit off the beaten path, with the caveat that I'll be strongly considering buying your kit next winter once the race season is over and I have some play money:
With this being a rallycross car, I have pretty limited interest in having a low-mounted FMIC. It would get limited air anyhow since I have a large skidplate, I'm thinking, but more importantly there is a big possibility of damage to it. Not sure how large the FMIC is exactly, but what about the possibility of a TMIC mounted (more or less) above/behind the radiator (over the fan, which on mine is a Spal electric). I already happen to have a large opening cut in the hood there anyhow (for general cooling) and could add a low-profile scoop a la Subaru Legacy. I guess my question is whether this would be a reasonable place to mount a TMIC, and/or what is the possibility that it would actually fit (including piping)?
Just curious. :)Stage rally/rallycross e30 build/competition journal
Track/street e21 build
visit Condor Speed Shop
visit Motorsport Hardware
[FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTIComment
I don't think there would be much room there to fit an intercooler. You might have to cut a HUGE hole to make it workwww.classicdaily.net
The intercooler is not that low, really. The bottom of it is basically flush with the bottom of the bumper.
I'm sure with a little more creative piping you could get one just behind the kidneys, especially if you get rid of the high beams.
The main problem with relocating things in the engine bay is the requirement to use the stock AFM. There is just no where to put it on the passenger side of the engine bay, so it has to make it's way across the front of the engine.
If that piping wasn't there, I think there would totally be room for a long intercooler in that space (which would also look badass with the scoop). You might be able to rotate the turbo so the outlet came above the intake, but then you would run into hood clearance issues.
Or you could just do what these guys did and move the radiator back. Vidya But then you run into AFM routing issues again.
Basically, if you go standalone engine management, you have a lot more options.Comment
You could switch to an IX washer fluid reservoir & free up some room in the passenger side...Comment
Leon, did you look at putting the AFM right in front of the turbo? I didn't play around with it too much but it looked like as a possibility. You could stuff foam behind the low beam and then squeeze the AFM right in to the foam. It wouldnt be a normal filter but rather a foam block or something similar with the AFM providing a pressure fit.The intercooler is not that low, really. The bottom of it is basically flush with the bottom of the bumper.
[ATTACH]83524[/ATTACH]
[ATTACH]83523[/ATTACH]
