Interest in Bolt on Turbo kit?
  • dpmcdonald
    • Feb 2014
    • 243
    #436
    Ordered! Decided to order and wait for the MAF setup. Very exciting!
    '91 318is turbo
    • jrockbk
      • Jun 2013
      • 369
      #437
      Originally posted by jntar
      Alpha-n and boost dont go together. You could always buy Jakes kit and then later on go with a megasquirt ecu. No changes would need to be made other than tuning.
      Will that allow the AFM to be removed? Would you need a MAF?
      • wazzu70
        • Jan 2005
        • 1143
        #438
        No dyno results yet? Seriously!!!
        -Nick
        M42 on VEMS
        • jntar
          • 459
          #439
          Yes. No. When you build your megasquirt unit you'll want to use an internal or external map sensor.
          M42 turbo build.
          http://www.r3vlimited.com/board/showthread.php?t=301330
          • dpmcdonald
            • Feb 2014
            • 243
            #440
            FYI, Jake thinks the MAF setup will remove the need to run the intake pipe across the front of the engine bay.
            '91 318is turbo
            • dpmcdonald
              • Feb 2014
              • 243
              #441
              Originally posted by MikeW
              To all Dyno shoppers:
              Jake has almost completed my kit and I will provide a before and after Dyno at 9 psi. I'm guessing I should have something by the first week of February if I get the kit in the next week or so.
              Should Santa put a new E30 M3 under my tree tomorrow than all bets are off.
              Did you ever get around to that dyno?
              '91 318is turbo
              • Ocell
                • Apr 2013
                • 291
                #442
                Tell you what, guys. There's a dyno that pops up at car shows here in town all the time. If everyone chips in to buy me a kit, I'll install it and pay for the dyno time. Come on, what do you say? Everyone wins, right??
                91 318is Members' Rides Thread
                • dpmcdonald
                  • Feb 2014
                  • 243
                  #443
                  I can't believe that anyone could strap on a turbo and not have to know what kind of power they are laying down! I have access to a dyno for less than $100. You better believe I will be laying it down right after I install my kit with the MAF setup. Would love to see a graph to compare to though...
                  '91 318is turbo
                  • xtos
                    • 81
                    #444
                    Very interested ....but ...any chance my A/C stays on ? Can't bare the heat here , it's my dd.
                    1990 318is M-technik2
                    • jakeb
                      • 1909
                      #445
                      yes AC can stay
                      www.classicdaily.net
                      1970 m42 swapped 2002
                      1985 LS1/T56 Swapped e28 (557e)
                      www.blunttech.com - For all your parts needs
                      Follow me on Instagram for constant build updates @classicdaily
                      https://www.facebook.com/ClassicDailyLLC
                      • brads2002
                        • Nov 2005
                        • 2688
                        #446
                        Kept my ac and it works fine.
                        • Jeff2886
                          • Nov 2011
                          • 52
                          #447
                          Just read all 30 pages of this thread (I don't think I've ever done that on ANY forum haha).
                          Subbing to keep tabs on everything.
                          Jake you'll likely be hearing from me soon!
                          • Jeff2886
                            • Nov 2011
                            • 52
                            #448
                            Email sent :P
                            • xtos
                              • 81
                              #449
                              ok thanks for your reply ppl , now that im sure A/C will stay im in .
                              • dpmcdonald
                                • Feb 2014
                                • 243
                                #450
                                Originally posted by Jeff2886
                                Email sent :P
                                Those of you just now ordering should order the MAF setup!
                                '91 318is turbo
