Originally posted by jakeb
View Post
Interest in Bolt on Turbo kit?
Daily: 06 Chevy Colorado (wannabe racetruck)
Drift/Track Car: 91 Bmw 318i 4dr
Originally posted by Reub_e30 View PostGreat! Also could I get it with a flange welded on for Tial q 50mm bov. Just checking because I already have a few parts from a previous build that I would like to use. Expect an order from me in a few months
jake@classicdaily.net is the best way to contact mewww.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC
Originally posted by jakeb View PostBest would be to email me....using a BOV and not a BPV will mess with the way the tune works.
jake@classicdaily.net is the best way to contact meYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by dpmcdonald View PostPerfectly placed FMIC.
Originally posted by econti View PostWhat size cooler, and do the headlight have to be modded to fit?
Originally posted by grinchxvx View PostHas anyone made 400 whp on a stock boosted m42? Just got a 318is that needs some love and don't know which direction I want to go with it, I like the idea of something different though. The car already feels so light I don't really want to swap it as of right now.
If they have, I would bet not for long! Lol.'91 318is turbo
Originally posted by grinchxvx View PostI keep forgetting it's not a 6 haha. I would probably be happy with 300whp honestly if I could keep the weight down still. May have to look into this kit, 2000 is dead ass cheap.
The size turbo that comes with this kit will be only capable of ~250whp. Tune is going to be key to hit even that. Have to be careful with the high compression ratio of these motors.
Agreed that this kit is an amazing value. The quality of fabrication is great as well. Great way to get into a turbo setup on the cheap. Could always upgrade the turbo later.'91 318is turbo
Originally posted by dpmcdonald View PostThe size turbo that comes with this kit will be only capable of ~250whp. Tune is going to be key to hit even that. Have to be careful with the high compression ratio of these motors.
You can get a BW s300 for 600 brand new and it's a good turbo that will flow more than this motor will ever make. maybe I'll just do that and try to find a manifold to run external wastegate. I wonder if you could make good power on e85, I know frank over on BFC made like 700whp for a long time on his stock m50 always beating on his car just because ethanol is so resistant to knocking.
300 is doable but not really with a stock engine..... Going to need head studs and a VERY good tune at the very minimum.www.classicdaily.net
Originally posted by jakeb View Post300 is doable but not really with a stock engine..... Going to need head studs and a VERY good tune at the very minimum.
FYI, I'm finally getting the standalone wired up. Going to put it on a dyno for some fine tuning and see how much boost I can safely throw at it on pump gas.
Will report back in a few weeks.'91 318is turbo
Just to add to the thread's gallery of finished installs, this is all done except for exhaust.
Finished M42 Turbo Engine Bay by Chris Owens, on Flickr
318is Turbo Install by Chris Owens, on Flickr
