Do you have a check engine light on? Do you have a wideband? Why do you think it is lean?
Interest in Bolt on Turbo kit?
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC
Originally posted by jakeb View PostDo you have a check engine light on? Do you have a wideband? Why do you think it is lean?
Yes there is an Innovate MTX-L wideband reading lean, and a Matco Maximus scanner plugged into the car with a lean o2 sensor voltage reading.
This kit is designed to run on the stock fuel pump and fpr, correct?
Originally posted by Balleristic31 View PostWhat clutch is everyone running with this kit?
What is the 'tune' used for this kit? Is it an EPROM chip or does this come with a standalone like MS2?318iS Track Rat :nice: www.drive4corners.com
Originally posted by downforce22 View PostWhat is the 'tune' used for this kit? Is it an EPROM chip or does this come with a standalone like MS2?Last edited by kinkier; 09-06-2016, 07:08 PM.
yes still being made, yes more of a reliability issue from chinese vs Garrett .
BEST way to contact me is via email, jake@classicdaily.net
thankswww.classicdaily.net
