Interest in Bolt on Turbo kit?
Best would be to email me....using a BOV and not a BPV will mess with the way the tune works.
jake@classicdaily.net is the best way to contact mewww.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLCComment
Ok man will do. How far have you been able to push the m42 with stock internals and head?Best would be to email me....using a BOV and not a BPV will mess with the way the tune works.
jake@classicdaily.net is the best way to contact meYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Daily: 06 Chevy Colorado (wannabe racetruck)
Drift/Track Car: 91 Bmw 318i 4drComment
You did a great job with that! Do you still have the condenser for your A/C? I'm in the process of getting everything installed and the condenser is keeping me from pushing the IC back as far as I think it will need to go to get the kind of fit you have there. I'm curious if you have any tricks or suggestions.Comment
I ended up cutting the headlight brackets like this. I know I needed to do it for the A/C line that runs under the high beam. I'm not sure if it was 100% needed on the other side, but I went ahead and did them both to give me room to work.
Has anyone made 400 whp on a stock boosted m42? Just got a 318is that needs some love and don't know which direction I want to go with it, I like the idea of something different though. The car already feels so light I don't really want to swap it as of right now.Comment
If they have, I would bet not for long! Lol.'91 318is turbo
The size turbo that comes with this kit will be only capable of ~250whp. Tune is going to be key to hit even that. Have to be careful with the high compression ratio of these motors.
Agreed that this kit is an amazing value. The quality of fabrication is great as well. Great way to get into a turbo setup on the cheap. Could always upgrade the turbo later.'91 318is turbo
You can get a BW s300 for 600 brand new and it's a good turbo that will flow more than this motor will ever make. maybe I'll just do that and try to find a manifold to run external wastegate. I wonder if you could make good power on e85, I know frank over on BFC made like 700whp for a long time on his stock m50 always beating on his car just because ethanol is so resistant to knocking.Comment
300 is doable but not really with a stock engine..... Going to need head studs and a VERY good tune at the very minimum.www.classicdaily.net
FYI, I'm finally getting the standalone wired up. Going to put it on a dyno for some fine tuning and see how much boost I can safely throw at it on pump gas.
Will report back in a few weeks.'91 318is turbo
Just to add to the thread's gallery of finished installs, this is all done except for exhaust.
Finished M42 Turbo Engine Bay by Chris Owens, on Flickr
318is Turbo Install by Chris Owens, on FlickrComment
