Interest in Bolt on Turbo kit?
  • jakeb
    • 1909
    #691
    Do you have a check engine light on? Do you have a wideband? Why do you think it is lean?
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • clueless
      • Jun 2016
      • 5
      #692
      No check engine light on.
      Yes there is an Innovate MTX-L wideband reading lean, and a Matco Maximus scanner plugged into the car with a lean o2 sensor voltage reading.
      This kit is designed to run on the stock fuel pump and fpr, correct?
      • gstuning
        • 833
        #693
        What is the compressor inducer and turbine exducer sizes?
        Gunni
        @ Prodrive / Aston Martin Racing
        • dpmcdonald
          • Feb 2014
          • 243
          #694
          I bought another M42 E30. I may be needing another kit!
          '91 318is turbo
          • El Guapo
            • Jul 2016
            • 2
            #695
            would like to order
            pm sent
            "Life is too short to drive a Camry"
            2000 e38 740il
            2002 e39 540i m-sport 6 speed
            1992 318ic soon to be turbo
            • Balleristic31
              • Aug 2009
              • 4198
              #696
              What clutch is everyone running with this kit?
              -NICK
              • ccsdo5
                • Mar 2013
                • 708
                #697
                I don't have jake's kit but I currently have a stock M20 clutch and single mass flywheel and it is holding up fine on ~7-8psi I think my turbo is about the same size as the one jake uses it is a T25 off an SR20. I plan on trying to get a spec stage 3+ clutch for my car when I up my boost to 15 psi in the future, I'll keep an eye on when mine starts to slip though.
                -Dee
                5-lugged turbo 318is Barn car
                IG: @deebelmont
                • TMACE30
                  • Jul 2013
                  • 37
                  #698
                  This was an amazing find! I will be in touch about a kit for my 91 318IC. Subscribed:)
                  1991 BMW E30 318IC Laguna Green/Tan
                  • downforce22
                    • Aug 2009
                    • 3192
                    #699
                    What is the 'tune' used for this kit? Is it an EPROM chip or does this come with a standalone like MS2?
                    • kinkier
                      • Jan 2016
                      • 8
                      #700
                      it is a EPROM chip, although I do believe he will be offering ms3 with the kit soon for an additional price.
                      • sandrune
                        • Sep 2014
                        • 87
                        #701
                        This bolt on kit still being sold?
                        Sent from my HTC6535LVW using Tapatalk
                        '91 318is
                        • LeMinouCool
                          • Jan 2016
                          • 17
                          #702
                          I'll need a kit as soon as i pile up, sold my 325is and the 318 i bought i just too slow...
                          will pm when im ready. if this is still available.
                          • LeMinouCool
                            • Jan 2016
                            • 17
                            #703
                            also, I've got a rb25 turbo lying around, do you recon it will mate with most of your kit?
                            I preffer used oem to Chineese stuff.
                            • J Mid
                              • May 2016
                              • 163
                              #704
                              Wow as soon as I get more money you can count me in for a kit. Just to be clear it's not a HP difference between the Garret turbo and the Chinese turbo, but more of a reliability/Garret is a proven brand thing right?
                              • jakeb
                                • 1909
                                #705
                                yes still being made, yes more of a reliability issue from chinese vs Garrett .
                                BEST way to contact me is via email, jake@classicdaily.net
                                thanks
