Do you have a check engine light on? Do you have a wideband? Why do you think it is lean?
Interest in Bolt on Turbo kit?
www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLC -
Yes there is an Innovate MTX-L wideband reading lean, and a Matco Maximus scanner plugged into the car with a lean o2 sensor voltage reading.
This kit is designed to run on the stock fuel pump and fpr, correct?Comment
I don't have jake's kit but I currently have a stock M20 clutch and single mass flywheel and it is holding up fine on ~7-8psi I think my turbo is about the same size as the one jake uses it is a T25 off an SR20. I plan on trying to get a spec stage 3+ clutch for my car when I up my boost to 15 psi in the future, I'll keep an eye on when mine starts to slip though.Comment
What is the 'tune' used for this kit? Is it an EPROM chip or does this come with a standalone like MS2?318iS Track Rat :nice: www.drive4corners.com
No one makes this car anymore. The government won't allow them, normal people won't buy them. So it's up to us: the freaks, the weirdos, the informed. To buy them, to appreciate them, and most importantly, to drive them.Comment
I'll need a kit as soon as i pile up, sold my 325is and the 318 i bought i just too slow...
will pm when im ready. if this is still available.Comment
also, I've got a rb25 turbo lying around, do you recon it will mate with most of your kit?
I preffer used oem to Chineese stuff.Comment
yes still being made, yes more of a reliability issue from chinese vs Garrett .
BEST way to contact me is via email, jake@classicdaily.net
thankswww.classicdaily.net
https://www.facebook.com/ClassicDailyLLCComment
