M42 Refresh Plan - Help
  • 2ndName
    • Sep 2012
    • 158
    Hello all,
    Needing some advice to layout my action item for my new to me 92 318ic. No real maintenance records but the car runs fine. There's a slight oil leak so that will have to be prioritize. In regards to preventative maintenance please provide what you would recommend that I do to get car in tip/top shape.
    Current action item:
    Oil leak - Diagnose and repair
    Oil drain - refill with 10w40
    Timing Chain Tensioner using M44 (part no. 11 31 1 743 187)
    The car is practically stock, no mods. I hear that I should refresh bushings, any particular brand/link? It's a 5 speed if that makes a difference.
    Thank you team.
  • Dj Buttchug
    • Jun 2010
    • 7688
    step 1: search the forum for tips. theres tons here
    step 2: mess under intake
    step 3: use 20w50
    step 4: inspect your timing gears/guides and chain and replace as needed
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Gerta
      • Sep 2009
      • 2119
      ^ I'd add to that list to drop the lower oil pan and check those bolts in the pan. If you are going to check and potentially replace the timing gears/guides this should be done as well.
      Parts Collector and Former Houndstooth interior junkie.
      • 2ndName
        • Sep 2012
        • 158
        Thank you both. Will add both to the list. Fun fun fun.
        • Gerta
          • Sep 2009
          • 2119
          Hit up www.m42club.com too ... lotsa good info there.
          • Threehz
            • 1480
            Why 20w50 oil?
            As for brands, it may seem obvious, but watch out for the cheap stuff. I always Google brand names that I don't know, and it's usually easy to find out if they are legit or crap.
            I usually use Pelican Parts for my parts needs and I have never had a problem with any of their brands (they carry OEM and off-brand for almost all parts), good prices as well.
            Different strokes for different folks.
            • bmwman91
              • Oct 2004
              • 3134
              Where are you seeing the oil leak / dripping from? There are 3 notorious spots: at the oil filter housing, where the 2 rubber profile gaskets meet neat the timing chain tensioner, and the gasket at the rear crank cover.
              Transaction Feedback: LINK
              • 2ndName
                • Sep 2012
                • 158
                Found the leak, 2 leaks to be exact. One came from the Power Steering Res. The other was due to the valve cover gasket.
