Just for reference, I am presently running a complete M20 clutch/flywheel setup. Flywheel, PP, disc, ToB are all M20 parts. No spacer ring. The thing is that it is an 11lb M20 flywheel, so it has no problem clearing the upper pan or whatever it is that the stock one interferes with. The clutch feels and works fine.
EDIT
You do need the starter pinion gear from a late model M20. Just crack your M42 starter open and swap that in, or just toss in an M20 starter.
EDIT
