mishimoto swap
  • Bimmer805
    • May 2012
    • 207
    mishimoto swap
    just did a mishimoto swap on my m42 and i was wondering if anyone can tell me any proper bleeding techniques?
    Luis
    Instagram: Bear_e30
  • Bimmer805
    • May 2012
    • 207
    bump
    Luis
    Instagram: Bear_e30
    • bmwguy325is
      • May 2011
      • 1263
      heater full bore open bleeder screw
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • gearheadE30
        • Jun 2007
        • 3734
        If it doesn't want to bleed, park on a hill so that the front of the car is higher than the back, and bleed it that way. If it still doesn't want to go, fill the radiator tank with the bleed screw open, parked on the hill, and fill until water is coming out of the bleeder which will pretty much be all the way to the brim, and then bleed it. You'll have to remove some coolant when you're done if you use this approach though.
        Project M42 Turbo
        • Bimmer805
          • May 2012
          • 207
          where is the bleeder screw on the mishimoto?i know the bleeder screw on the old m42 radiator was on top but i cant seem to find it on this radiator.
          Luis
          Instagram: Bear_e30
          • dude8383
            • Jan 2005
            • 10387
            No bleeder screw on a mishimoto but where is your reservoir?
            • Bimmer805
              • May 2012
              • 207
              im using the stock m20 reservior
              Luis
              Instagram: Bear_e30
