M42 engine stand mounting bolt size??
  • Beemerdan
    • Nov 2012
    • 192
    I am wondering what size bolt I need to put an M42 on to an engine stand?
    Thanks!
    Dan
  • roguetoaster
    Biggus Tippus
    • 7830
    IIRC they are M12x1.5 or you can just use your transmission mount bolts if you like. Let us know if this is correct.
    • Dj Buttchug
      • Jun 2010
      • 7673
      that is correct. use trans bolts. makes it easy
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Beemerdan
        • Nov 2012
        • 192
        I bought the car with the engine out, and no trans bolts. I picked up m12x1.5 bolts yesterday, but they are not the right size.
        • jakeb
          • 1909
          They are not all the same size....The top ones are m12, there are a couple m10 (starter) and down lower are m8.
          http://realoem.com/bmw/showparts.do?...99&hg=23&fg=10
          I think the top ones are m12 x 1.75 pitch. Whatever standard coarse thread is.
          www.classicdaily.net
          1970 m42 swapped 2002
          1985 LS1/T56 Swapped e28 (557e)
          www.blunttech.com - For all your parts needs
          Follow me on Instagram for constant build updates @classicdaily
          https://www.facebook.com/ClassicDailyLLC
          • roguetoaster
            Biggus Tippus
            • 7830
            Ah, well my apologies for steering you wrong, looks like jakeb picked up the slack. But you will still need to get some transmission bolts, so, two birds one stone?
