e30 m42 idles up and down then dies
  • 318iskid
    • Jan 2013
    • 11
    After running for a little bit, my '91 318iS's idle will rise and drop and eventually cut off. After it cuts off it won't start for about 1-2 minutes, it has also started cutting off even while I'm driving. I replaced the fuel filter last night and also replaced the idle air control about a year ago. Any help would be greatly appreciated.
  • bmwm42
    • 6300
    Did you install the lines backwards?
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • 318iskid
      • Jan 2013
      • 11
      Of what? The fuel pump? I replaced the fuel pump thinking it'd stop the idle problem.
      • Dj Buttchug
        • Jun 2010
        • 7686
        crank sensor. also vacuum leak possibly or ICV problems causing the idle to hunt
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • InNeedOfBoost
          • Aug 2012
          • 512
          Mine did that when the ICV crapped out, could be the crank sensor or even the MAF going out too. Disconnect your ICV and drive it around for a min and see if that makes a difference. Do the same with your MAF.
          1991 318is - Daily/weekend track car.
          An on-ramp is a terrible thing to waste...
