M42 valve cover bolts
  • lolcantturn
    • 4588
    I took off my valve cover, when I tried putting it back on almost none of the bolts seem to get tight at all. Is this common? What should I do?
    Originally posted by TSI
    OEM+
  • Anthony B
    • Nov 2012
    • 308
    Helicoils on the head, it's not uncommon when over tightened that the threads on the head are damaged my m40 has similar problems & my m42 has two threads on the head with helicoils in it
    • lolcantturn
      • 4588
      and it's not like this is my first time wrenching, I know how to take off and put a bolt on thank god. Just very weird. It's not leaking but I don't feel confident in it
      OEM+
      • salvuhdor
        • Jan 2013
        • 445
        These bolts take about 8lbs of torque. If too tight you have lost the thread. Time to learn how to helicoil
        • vpilarrt
          • Jun 2006
          • 2096
          The M42 valvecover bolts are designed to tighten fully against the head. The protrusion is sized to apply the correct amount of squeeze on the valvecover gasket. So if they keep spinning the female threads in the head are stripped.
          • lolcantturn
            • 4588
            Fair enough. I bought new bolts that are about 3 threads longer than the old bolts, fitted it with the rubber boots and spacers and they seem to have done the trick.
            OEM+
            • roguetoaster
              Biggus Tippus
              • 7830
              Seems like a good solution vs a Helicoil. I am assuming you used a straight through bolt rather than the stock double shouldered?
              • bmwman91
                • Oct 2004
                • 3134
                The threads in the head will ALL die eventually. Constant thermal expansion/contraction cycling will ensure that as the aluminum and steel parts expand different amounts. The rubber bushings are supposed to help, but they don't.
                I had to helicoil every damn one.
                http://bmw.e30tuner.com/articles_vchc.php
                Transaction Feedback: LINK
                • lolcantturn
                  • 4588
                  standard straight through bolt.
                  OEM+
                  • M-technik-3
                    • 18946
                    great write up
                    • Threehz
                      • 1480
                      Seriously good write-up. When I did the valve cover I found a couple of mine to be stripped, will definitely be referring to this at some point.
                      Different strokes for different folks.
                      • Nick_S
                        • Apr 2011
                        • 3658
                        Just had to helicoil every freakin one also. About $40 in parts and 2 hours time if you're moving slow and you'll be set. Used that write up as a reference because I've never done it, was painlessly easy.
                        91 318is M50 swapped
                        05 Honda Pilot
                        24V swap thread
                        • kwill22
                          • Apr 2009
                          • 962
                          The longer bolt solution will only work for so long. Dependent on how manny times you take your cover off. I did that as a quick fix to mine and the holes eventually wore out again. And I got tired of adding spacers and trying to get very hole perfect.
                          I eventually just got some threaded inserts from grainger and did all of my holes except for the 2 that weren't damaged.
                          DENY IGNORANCE!
                          Schwarz 325-totaled
                          brilliantrot 318i-daily
                          Originally posted by mkcman17
                          don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                          • Dj Buttchug
                            • Jun 2010
                            • 7678
                            the best way to fix this problem is convert to valve cover studs. run 8x1.25 studs with washers and 10mm nuts. all the stuff can be found at ace hardware.
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • Bimmian89
                              • May 2012
                              • 170
                              Use time certs. 1000X better than helicoils.
                              Check out my build thread!! :p
                              http://www.r3vlimited.com/board/showthread.php?t=288383
