Car loses power under heavy acceleration!! Help me please
  • bsturman92
    • Sep 2012
    • 282
    Ok so I have a 318is and recently installed a LSD... Car has been running fine fora while andi have been doing doughnuts for fun and a little drifting... Starting the other day sometimes when I go to burnout to turn around or do doughnuts when it's hits rev limiter it will just completely lose power and almost die.. I have to push the clutch in.. Come to a stop..then go... Can someone please tell me what this may be? It's only while hitting rev limiter.i have been able to bounce off it fora minute but now it does this
    Edit: I had JUST installed a new gas tank
  • Dj Buttchug
    • Jun 2010
    • 7688
    fuel cut.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • bsturman92
      • Sep 2012
      • 282
      That would make sense I JUST installed a new gas tank..what would be a good way to fix this issue??
      • roguetoaster
        Biggus Tippus
        • 7830
        Stop hitting the rev limiter, it's there for a reason. Peak power is at what, 5600-800 RPM?
        • F34R
          sLaughter
          • 12376
          Do you see the button above the window switches? That is a sport button in the 318is. I highly suggest engaging when doing sporty things like Donuts and powerslide drifts.
          The best thing you could do is install one of those air box supercharger fans from ebay. They really force the air in when you are giving the car full gas.
          Good luck!
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • george graves
            • 20003
            Good luck!
            I've got one. It worked, but not that well, so I installed a second one - one right after the other - now it rocks. At least 175 HP.
            Originally posted by Matt-B
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              You're not shifting right. If you can get into third while doing doughnuts it won't cut out at all.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • Gregs///M
                • Mar 2012
                • 2459
                This could be a few things but my guess would be AFM. Check my thread on AFM in my signature for more info why this happens.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • Threehz
                  • 1480
                  Did you check the new gas take for gremlins before installing? Also check your cat, hitting the r3v limit too much makes it prone to singe the hairs around the ears and tail.
                  Different strokes for different folks.
                  • LJ851
                    • 7919
                    The M42 engine uses a really sophisticated ECU for it's time and one of the features it boasted was a limited number of rev limits for a given period of time. I haven't heard of too many people using up the available rev limits, but it sounds like you did.
                    If you chill and don't hit the limiter for a while you should be able to build up a reserve.
                    Lorin
                    The M30 is God's engine.
                    • bsturman92
                      • Sep 2012
                      • 282
                      ^ that's interesting I never heard of that.. It only happens sometimes not all the time though that's the thing
                      • LittleEcker
                        • Oct 2012
                        • 83
                        Good luck!
                        Wait... the 1991 318is has a sport button? I didn't think they came in until later!
                        -Experience is what you have right after you need it
