Switching to synthetic oil
  • wazzu70
    • Jan 2005
    • 1143
    Originally posted by TobyB
    Not anymore, it doesn't. "LE" Rotella has something like 800 ppm, not really enough.
    The Mobil 15-50 is pretty good at 1200 ppm.
    Or you can just put in a bit of ZDDP additive- several reputable cam manufacturers
    market it, and they stand behind their cams... when used with it.
    fwiw
    t
    Like Toby said, you can buy ZDDP additive to make sure you are getting a proper amount :)
    -Nick
    M42 on VEMS
    • noid
      • 1535
      fwiw
      t
      I emailed shell in regards to this in September and this was their response:
      From: "shelltechnical-ca@shell.com" <shelltechnical-ca@shell.com>
      Sent: Monday, September 24, 2012 1:45:49 PM
      Subject: RE: Oil zddp levels and tappet engines. Your reference 35180422
      Hi,
      We no longer make a 20W-50 engine oil but you can use Shell Rotella T Triple Protection 15W-40, which contain a ZDDP level higher than 1100 ppm.
      Regards
      Bello
      15w40 is more then sufficient for our engines because Rotella T/diesel oils have a much higher thermal breakdown resistance over gasoline oils.
      We are talking about an oil that is 12 dollars a GALLON at wal-mart.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • Threehz
        • 1480
        Just going to chime in because I have done a great deal of research on oil since I got into cars and especially to find the perfect one for my M42 since no one ever seemed to agree.
        Don't run synthetic oil in your M42. It was not designed for it, it will not help, and it will be worse for your engine than running a good mineral oil. It won't harm your engine, but using a good mineral oil will be much better for your engine.
        Use Castrol GTX. ZDDP is a little over 1400ppm, and it ranks among the best for flash, pour, and ash in each weight grade.
        10w30 Castrol GTX year-round, or in very cold climates bump down to 5w30 in winter.
        Different strokes for different folks.
        • Vtec?lol
          • Dec 2009
          • 3278
          Castrol GTX or Rotella.
          use a little trans fluid in the oil toward the end of the oils life to clean up sludge. Works excellent.
          • noid
            • 1535
            I would recheck those ZDDP numbers, I consulted Castrol directly and they suggested AGAINST using their GTX oil in tappet engines.
            Here is their email response:
            Sent: Friday, September 21, 2012 11:29:18 AM
            Subject: Ticket#37242/Castrol/Looking for oil for a flat tappet engine -- has been updated
            --Please enter your response above this line--
            This ticket has been updated by VF - Castrol Representative
            Thank you for contacting Castrol
            Classic cars with flat tappet cam engines represent a special case in regards to engine oil lubrication. These engines have valve train configurations that require elevated levels of zddp (zinc dialkyl dithiophosphate) anti-wear for proper protection of the flat tappet camshaft and its lifters. Insufficient concentration of zddp will lead to premature wear and failure of the camshaft and lifters. Current GF-4 and GF-5 fuel economy grade engine oils are designed for extended life of the catalytic convertors in modern passenger cars and have industry mandated limitations on the amount of sulfur and phosphorus within the oil.
            Castrol SYNTEC 20W-50 classic car formulation has been replaced by Castrol with SYNTEC Power Technology 5W-50 viscosity grade. The 5W-50 grade has also been specially formulated for classic car use and has adopted the 20W-50 claims - designed for use in classic cars. The 5W-50 formulation contains more zinc additives than the 20W-50 and will also enhance start up ability in cold temperatures as well as enable better fuel economy.*
            *Compared to SAE 20W-50.
            Castrol always recommends following the guidelines of the original engine manufacturer for the recommended grade and API specific to your application. This information can be found in the vehicles owner's manual or by contacting the manufacturer directly.
            Castrol Consumer Relations
            • Solarian
              • Oct 2012
              • 121
              How's the BMW branded synthetic oil? I got some from my local dealer for cheap due to a promotion they had. I haven't put it in because my car is still in pieces, but there was a big deal being made about only using BMW branded coolant, so I figured the oil would be good too. This is a pic of it. http://imgur.com/a/S4jJz
