M42 coolant
  • Beemerdan
    • Nov 2012
    • 192
    M42 coolant
    Does the M42 need a special type of coolant? or can I just use the all makes/all models stuff?
    Thanks!
  • Gerta
    • Sep 2009
    • 2119
    No you need to get the proper coolant or you will develop 'green goo'... Search the forum for the correct type. I personally use BMW coolant only.
    Sent from my DROID RAZR using Tapatalk 2
    Parts Collector and Former Houndstooth interior junkie.
    • Balleristic31
      • Aug 2009
      • 4198
      BMW coolant in mine as well. The PO put in standard green and it created a lot of buildup of crap in my cooling system
      -NICK
      • TobyB
        • 5286
        Plain green has worked just fine in mine for the last 3 years...
        ...it's mixing the types that generates the goo.
        t
        • InNeedOfBoost
          • Aug 2012
          • 512
          I've been using the blue BMW stuff.
          Anyone have any experience using water wetter/distilled water mix? I've run that in almost every car I've owned...but never heard anything as far as using it in the M42's
          1991 318is - Daily/weekend track car.
          An on-ramp is a terrible thing to waste...
          • roguetoaster
            Biggus Tippus
            • 7830
            WW and distilled water should be just fine, we run it in the Chump Car and I run it in my daily in warm weather.
            • salvuhdor
              • Jan 2013
              • 445
              Question for you fellas, I just replaced a the water pump and thermostat along with lots of other things now I am wondering if I should run the car with distilled water first then add after a couple miles drain it and add the BMW coolant I bought for it. Should I be fine? or should I not add the distilled water?
              • bmwman91
                • Oct 2004
                • 3134
                Distilled water and regular Prestone green have been fine for me for the 13 years that I have owned M42's. No corrosion or green go. There is nothing exotic about the M42 that calls for fancy coolant.
                Transaction Feedback: LINK
                • bmwm42
                  • 6300
                  I use zerox g05
                  Originally posted by bmwm42
                  PNW vulture pm me for parts
                  Strategic nw e30 command
                  • unevolved
                    • Nov 2011
                    • 714
                    I use the tears of my enemies.
                    1991 318i SOLD
                    2003 325i SOLD
                    Racecars and stuff.
                    • MF DOOM
                      • Apr 2012
                      • 944
                      i use tap water.
                      • SpecM
                        • Oct 2005
                        • 4531
                        Originally posted by MF DOOM
                        i use tap water.
                        lols
                        I use g05 in my m20
                        1989 cirrisblau-metallic 325i
                        • InNeedOfBoost
                          • Aug 2012
                          • 512
                          This literally made me LOL!!
                          I need to flush mine, the coolant has been in there since I got the car two years ago. Looks like I'll be going the water wetter route...it gets too damn hot in the south!
                          • Beemerdan
                            • Nov 2012
                            • 192
                            ^good question. is there anything wrong with running it for a few minutes with water in order to flush it out??
                            also does anybody know how much coolant it takes?
                            • InNeedOfBoost
                              • Aug 2012
                              • 512
                              That's usually what I do to flush coolant on any other car I've owned. Never had an issue.
                              From what I read, the M42's hold just under 2 gallons of coolant minus the overflow. Correct me if I'm wrong though.
