Shooting Fire
  • bmwman91
    • Oct 2004
    • 3128
    Reconnect that O2 sensor man. I promise that the car will run a LOT better when you do.
    Transaction Feedback: LINK
    • Dj Buttchug
      • Jun 2010
      • 7633
      op is constantly running in open loop?
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • duleymane///iS
        • Jun 2012
        • 153
        Originally posted by Eric
        Sounds like the problem is behind the steering wheel.
        Also a true statement.
        • duleymane///iS
          • Jun 2012
          • 153
          Picked up one today at a local auto parts store. 100 Euros... FML Put it in still chasing idle and car running about the same havent noticed anything else. Took it for a drive through some twisty German roads through the mountains and the car is just so much fun. Its weird the car runs fantastic in the higher RPM's and just lumps around in the lowers.
          • bmwman91
            • Oct 2004
            • 3128
            Sounds like a dirty idle control valve and a vacuum leak. Also try resetting the DME. It has learned all sorts of bad corrections as a result of the sensor being snipped.
            • Asbradley21
              • Jun 2008
              • 1938
              My no-cat free-flow-muffler m42 would do this occasionally. Although not nearly like that.
              S54B32 swap in progress. Status: Getting There
              • loganwept
                • Aug 2012
                • 153
                Originally posted by dannyyisntt
                your car shoots flames because racecar
                +1
                leave me some feedback if you've bought from me or I've bought your stuff!!
                http://www.r3vlimited.com/board/show...09#post3438509
