M42 ticking coming from head during idle then will go away?!?
  • bsturman92
    • Sep 2012
    • 282
    Ok so for a while when I start my car and is idling it makes a tick tick tick noise then will randomly stop... Then start again.... Sometimes go away when I give it gas.... But it's deaf coming from the head what do u think it could be
  • Quadrajet
    • Jul 2008
    • 1278
    Cam follower. Similar to a lifter tick on domestic cars. Have had the same thing with my old daily for years. Mine will do it till the motor warms up, then I don't hear it again, till this motor has sat for a few hours.
    • bsturman92
      • Sep 2012
      • 282
      Any way to resolve it? Car sat the last 3 days and is now louder than ever
      • Dj Buttchug
        • Jun 2010
        • 7688
        Not similar to lifter... it is lifters.
        its normal in higher mileage m42s. change to a higher viscosity oil to quite it down
        edit: If car sat for a long time 100% LIFTERS.
        Drive it around and get the oil pressure up. above 3k rev. it will stop
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Quadrajet
          • Jul 2008
          • 1278
          I meant similar, only in the fact that most SOHC domestics used a cam-lifter-pushrod-rockerarm setup.
          Switching to a thicker viscosity oil didn't help, even when it started to get cold up here.
          • Nick_S
            • Apr 2011
            • 3658
            I've always run 10w40 in my m42 but to keep the lifters quiet on my m50 I run 20w50. Works pretty well.
            91 318is M50 swapped
            05 Honda Pilot
            24V swap thread
            • Dj Buttchug
              • Jun 2010
              • 7688
              thats because these style require adjustment and are not self adjusting like the m42 ones.
              Ig:ryno_pzk
              • Balkanac
                • Apr 2011
                • 50
                i have had the same noise since i got the car.
                I ran the oil flush and used fully syn 0W40. Drove it on the open road for a few hours doing 120-130km\h and when i got back home the noise was gone
                But then i left it for a few days and when i started it the noise was back for a few seconds
                I guess they need to be replaced
                1991 BMW 318is Brilliantrot
                1998 Jeep Cherokee TD Black
                • Balkanac
                  • Apr 2011
                  • 50
                  • Quadrajet
                    • Jul 2008
                    • 1278
                    Actually they were manually adjusted only on the High Perf models in the 50s 60s early 70s -labeled mechanical cams, many 300-350hp motors had hydraulic adjustable lifters-labeled Hydraulic cams. Once emissions started to get around it spelled the doom of the Mechanical cam in domestic cars.
                    When I got into E30's I was surprised the valvetrain didn't utilize "set once" hydraulic lifters. But a collapsed lifter sucks just the same.
                    • I8UR911
                      • Jan 2013
                      • 260
                      Its not lifters...... its a crack in the exhaust manifold. It goes away when warm because when hot the manifold expands sealing the crack. Been there, done that :)
                      Sent from my XT907 using Tapatalk 2
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        a possibility although less common.
