Loose tranny bolts/missing!!
  • bsturman92
    • Sep 2012
    • 282
    Alright so I was replacing my guibo and CSb and saw my tyranny bolts are finger loose! And 1 or2 is missing... Why could this be and what should I do? And there is still a clunking sometimes when I'm cruisin in first or second and push clutch in and take out of gear... Like coming to a speedbump or somethinit will clunk real good lol
  • Quadrajet
    • Jul 2008
    • 1278
    Hmmmm were you able to tighten all the remaining bolts? Sounds like perhaps the clutch fork is trying to push the engine and trans apart?
    • bsturman92
      • Sep 2012
      • 282
      No I don't have the proper tool to grab the bolts! Idk wat kinda socket I need... They are like Torx head or something not too sure... Do unknow?
      • roguetoaster
        Biggus Tippus
        • 7830
        They are torx head, I forget the size, using a female torx socket. In a pinch you may be able to get a 12pt standard socket on there and tighten them down.
        • Dj Buttchug
          • Jun 2010
          • 7678
          this happens periodically to all my m42 engines. Just use a bit of locktite on the threads to keep them from backing out. problem solved
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • roguetoaster
            Biggus Tippus
            • 7830
            I assume you are running non stock engine/trans mounts? On stockers I have not experienced this. Maybe something else to check on the Chump.
            • Dj Buttchug
              • Jun 2010
              • 7678
              all stock mounts. Theres a chance I may have not tightened them down enough and that could be the reason.
              Ig:ryno_pzk
              • Quadrajet
                • Jul 2008
                • 1278
                I've got a set of those sockets in my shop just for that, I'll be out there tomorrow and look and see which ones you'll need.
                • bmwman91
                  • Oct 2004
                  • 3134
                  Wait, the E-head (inverted Torx) sockets that hold the tranny to the block are known to loosen and fall out? I haven't seen that on either of my M42's in the 13 years that I have driven them. Granted, I have a tendency to over-tighten things lol.
                  Transaction Feedback: LINK
                  • bsturman92
                    • Sep 2012
                    • 282
                    Yeah I have stock motor any tranny mounts... I'll swoop up some locktite..n yes quadrajet if you could tell me the exact socket size I need I would appreciate thAt.... This is off topic but any of you use the 535i motor mounts by chance? Considering buying some... And maybe 320i tranny mounts as well? Any opinions?
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      Go with stock engine mounts (rockauto often has them for a low price) and save the added NVH of the non hydros. Definitely upgrade the transmission mounts as the ones on my cars have not lasted as long as I would have hoped.
                      • bsturman92
                        • Sep 2012
                        • 282
                        What are some good upgrades for tranny? Go with poly? Or a stronger stock like a 320i tranny mount.
