Loud screeching noise= flywheel?
  • freeride53
    • 11972
    So i've had this loud intermittent screeching noise for the last year or so.
    it comes usually on start up, and gets louder/comes with when revving the car.
    what could this be? i'm starting to get it now upon take off from stops now as well.
    it's funky.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • Dj Buttchug
    • Jun 2010
    • 7688
    Belts?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • vpilarrt
      • Jun 2006
      • 2096
      Water pump, alternator, PS pump or AC comp bearings?
      • Kozworth
        • May 2011
        • 1339
        Pull each Belt off until the screech goes. Once I goes inspect all pullies for excessive wear. Look for score marks on timing covers or close areas. Not sure if this applies to the e30 but inspect to make sure your not adding or missing washers
        • mr ilia
          • May 2011
          • 582
          Could be belts, unless...
          Does the noise have a "metallic" tone to it? And mostly happens when you actually work the starter?
          If "yes", to both, then this is your trater soleinoid scratching the flywheel.
          • ttrousdell
            • Nov 2009
            • 1770
            Because you said flywheel im going to assume you think its coming from the back of the engine. Could be your pilot or throw out bearing going bad.
            The Build:
            • Beemerdan
              • Nov 2012
              • 192
              Check the belts. I had the same problem with my M42. Tightened up the alternator and it went away.
              • GillesBigCowboy
                • 507
                All my belts were loose, but just tightened them yesterday and my screeching is gone,
                87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                • UpOn3
                  • Feb 2013
                  • 62
                  great. What's the rule of thumb to tell if they are tight enough? When tight, how much if any rotation can you get from twisting the belt at it loosest spot?
                  • horror business
                    • Jun 2010
                    • 11
                    There is actually a measurement tool for it. You adjust a device to click when a certain amount of pressure is applied. You can sometimes find the number on Mitchell's.
                    Try spraying water on the belt to see if the noise goes away temporarily.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Rule of thumb is you should be able to turn the belt 90ยบ by hand, but no further. I.E. - Grab the belt between two pulleys and rotate it as far as you can. Shouldn't turn more than a 1/4 tun.
                      • travish325
                        • Jun 2012
                        • 1151
                        Originally posted by Dj Buttchug
                        Belts?
                        Bet it's belts....
