Timing Chain Guide Separating
  • Earl
    • Feb 2013
    • 31
    I just inspected my timing case to notice the plastic, on the chain guide on the left, was separating from the metal. I believe the part number for my guide is 11311247483. I noticed there were two part numbers listed. The other one was 11311247470. This seems to be an all plastic version. It seems that it would be a better alternative since it is one solid piece. Which one should I go with?
  • bmwman91
    • Oct 2004
    • 3134
    The all plastic one is an updated design and should be used.
    Transaction Feedback: LINK
    • Dj Buttchug
      • Jun 2010
      • 7688
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Earl
        • Feb 2013
        • 31
        Well there ya go. Thanks for the quick response:) Do you happened to recall the torque called out on the bolts holding it down? I should be okay replacing this guide and leaving the other ones correct? I did not see any major wear or damage to the others.
        • bmwman91
          • Oct 2004
          • 3134
          No idea on the bolt torque. Can't find those in the Bentley. I have always just used red LocTite on those allen bolts and tightened them to whatever feels right. I know I know...
          One VERY important thing to note here. The later model all-plastic rail requires a 45mm bolt at the top. The original one is 40mm and you are guaranteed to strip the top hole if you use the old one. Go find yourself an M6x45 grade 10 or better bolt at a local hardware store. The chances of you stripping out that top bolt even with the 45mm bolt are still high (it has happened to me on both of my engines) and I have had to install helicoils there. You can do it with the rail still installed if you have to, just make sure to have a shop-vac right there when you drill and tap. Using cutting oil also helps keep the metal chips on the bits instead of falling about.
          • Dj Buttchug
            • Jun 2010
            • 7688
            the new guide should come with new correct hardware to install it.
            Ig:ryno_pzk
            • Earl
              • Feb 2013
              • 31
              The previous guide also had the adjustable upper sleeve so I believe my existing bolt should be the proper length. I'm not too worried. I should be able to source a bolt if need be. I forgot to mention but the m42 is out of my 95 BMW 318ti.
              • bmwman91
                • Oct 2004
                • 3134
                Hmm, never had a new bolt come with mine. Just the adjuster sleeve.
                Just make sure that the bolt threads are 45mm long and you should be OK.
                • Gerta
                  • Sep 2009
                  • 2119
                  Chugz -I ordered my parts from blunt recently and this did not come with it.
                  Parts Collector and Former Houndstooth interior junkie.
