Low water Temp readings
  • UpOn3
    • Feb 2013
    • 62
    I got this car not long ago and notice that the temp never goes past 1/4 mark. I think this may be due to a low temp thermostat or one that is stuck open.
    Is there any reason to have a low temp thermostat?
    Is it a bad thing to run it a little cooler or have the coolant constantly circulating through the head? Is it better for performance and worse for fuel economy?
    TIA
  • roguetoaster
    Biggus Tippus
    • 7830
    It's probably a stuck thermostat.
    Low temps may equal more power, but that would also give you bad mileage.
    Essentially, it seems to be new thermostat time.
    • Dj Buttchug
      • Jun 2010
      • 7688
      either that or its a drilled t stat, or none at all.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • duleymane///iS
        • Jun 2012
        • 153
        I have had this same problem since I got the car over a year and a half ago. It creeps up to half sometimes as I sit in traffic and its 85+ outside. It normally hovers in the blue or just at 1/4. Have never had a problem other than it takes FOREVER to warm up in the winter. PO said he had just replaced the thermostat a week before he sold it to me. IDK never really bothered me.
        • roguetoaster
          Biggus Tippus
          • 7830
          It's also possible that the thermostat is in backwards. However, I am not sure if that would cause it to function the way you describe.
          • jrobie79
            • Mar 2006
            • 2526
            I have changed the thermostat three times in my m42, running BMW coolant with water wetter and it barely gets to halfway between 1/4 and 1/2 while running. I don't have my aux fan connected yet and it creeps up to and sometimes past halfway when I'm idling or stuck in traffic for more than 5-10 minutes.
            1991 318i ---- 308K - retired
