M42 Vehicle Speed Sensor/ Timing off/ Bad Idle?
  • lolcantturn
    • 4588
    Originally posted by Dj Buttchug
    what about fuel pump? checked pressure?
    Nope I have not. I figured my problem either lies in the fuel pump or the timing is off. I will get on testing that fuel pump though.
    Chances of it being the fuel pump though?? I figured its not since the car doesn't break up at higher RPM's.
    Originally posted by TSI
    OEM+
    • Dj Buttchug
      • Jun 2010
      • 7673
      hmmmm it cant really be timing... The car drove fine and then all the sudden this happened timing is unlikely.
      It very well could be a weak pump. Weird things happen when they start to fail. How many miles are on the current pump?
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • lolcantturn
        • 4588
        Probably infinity miles. Just kidding, but a lot. I'm gonna guess 80k-100k. Doesn't whine or anything. I've put 21,000 miles on this car, the idle has always been erratic like it is now. The pump would have gotten gradually weaker I feel.
        OEM+
        • Dj Buttchug
          • Jun 2010
          • 7673
          dont throw parts at it. Get a fuel pressure tester and see where you are at. report back after. its something stupid. eliminate easy things first.
          Ig:ryno_pzk
          • bmwm42
            • 6300
            check your harmonic balancer
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • Sladek
              • May 2016
              • 228
              just found this from digging for solutions to my current problem and it sounds very similar if not identical. was this ever resolved?
